RE: Hotend temperature
Hiya;
Normally if the temperature jumps when the extruder is moving side to side is a sign that the thermistor wire is broken. You can double check it without preheating the nozzle. Have the stepper motors unlocked so you can move the extruder by hand, then move the extruder side to side, if you notice the temperatures changing then more than likely the wire has a pinch and the wires are snapped and you would need to replace the thermistor.
Shane (AKA FromPrusa)
Postato : 08/11/2022 10:36 am
Topic starter
answered:
in this video are two Temperature jumps (and btw a lot of stringing)
is this normal ?
Postato : 08/11/2022 8:16 pm
not really
is this normal ?
no it's not. see Shane's post...
Postato : 08/11/2022 10:02 pm
