Hotend is not heated up (Prusa i3 MK3)
Thomas Scheer
(@thomas-scheer)
I had to disassemble the extruder to remove a piece of filament from the PET tube. After reassembly the hotend does not heat up. When I try "Preheat" the side fan starts, the screen shows "Orginal Prusa ....", the fan turns off again. The temperature is displayed on the screen nozzle and bed 21 °.
When I try to change the temperature via Settings - Temerature - Nozzle- the printer always reboots and the screen displays "Orginal Prusa ....". when I try to change the temperature via Settings - Temerature - Nozzle- the printer always reboots and the screen displays "Orginal Prusa ....".
Can someone help me please. Thank you.
Opublikowany : 24/11/2022 3:44 pm
RE: Hotend is not heated up (Prusa i3 MK3)
Good evening Jean,
It sounds like your heater wires are short circuiting. which can cause your printer to reboot.
Opublikowany : 24/11/2022 4:20 pm
Thomas Scheer
(@thomas-scheer)
Hi Joan,
Thanks for the quick reply.
What can I do now. Do I have to replace the heater completely?
Regards Tom
Opublikowany : 24/11/2022 4:38 pm
If you can see the wires touching each other, try and ease them apart gently. hopefully they short circuit will disappear, if so, you can resume printing.
If that doesn't work, I Would consider ordering two heaters and two thermistors. thermistors are easily damaged, so you will have spares incase you break the existing thermistor and spares for next time you have a problem...
another option, may be to consider a Revo6 hot end...
Opublikowany : 24/11/2022 11:34 pm
Thomas Scheer
(@thomas-scheer)
Hello Joan,
Thank you very much for your answer. The heater wires do indeed have a short. I think the resistance should be 14.4 Ohms. I have ordered two new heaters (24V 40W).
With kind regards,
Tom
Opublikowany : 27/11/2022 3:51 pm
