Hotend cooler too close to surface
P. Larsen
(@p-larsen)
I've been printing with the MK3 for about a month now - I'm very happy about the printer generally - I've had very few issues with it compared to other printers I've used.
When I assembled it, I over-tightened the air-vent for the extruder so I had to print another (this is why I love 3D printing - I 3D print new printer(parts)). I used the Prusa PLA that came with the printer - so it's not exactly the best for high heat, but I figured it was far enough away from the hotend to not be that warm. And for about a month it's been doing great.
But lately I've heard scrabing. The other day, it killed a print (crash) because the fan actually HIT the top of the the object and blocked movement - it was a 10+ hour print that failed in the last 30 minutes of the print. I've tightened the fan, it will NOT move, but it still seems too close. Here's an image of a first layer print that fails because the fan is hitting the printed parts when the carriage moves.
Has anyone had similar issues and found a solution? I'm wondering if the fan has "bent" a bit and that I need to print another in a better material?
Veröffentlicht : 22/04/2018 7:12 pm
stahlfabrik
(@stahlfabrik)
Re: Hotend cooler too close to surface
Use abs for that part. Pla is the wrong choice because it melts
Veröffentlicht : 22/04/2018 8:28 pm
Olef
 Olef
(@olef)
stahlfabrik is correct. PLA is no use here, ABS is required at least. Even that has been seen to droop after a while.
Veröffentlicht : 22/04/2018 9:24 pm
Kwaad2
(@kwaad2)
Yeah, cooling nozzle MUST be at least PETG. Best would be Nylon or PC.
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Veröffentlicht : 22/04/2018 10:30 pm
