Hot End heater broken
greg_abram
(@greg_abram)
Hi -
Just got my mk3s for a few weeks and it's been awesome!  But today out of the blue I received a thermal runaway error and the machine wouldn't heat up.  I quickly realized one of the wires leading to the heater (the cylindrical piece the fits in the block - I cannot remember what it is called if it has a fancy name) broke off.  Is that fixable without replacing it?  Or do I need to replace??  Any direction would be appreciated.
Opublikowany : 24/07/2020 9:27 pm
RE: Hot End heater broken
If one of the wires has broken off near the heater case, you need a new heater
for the Mk3S you need a 40 watt, 24 volt heater,
Available from Prusa (Expensive)
e3donline, (UK) (Beware the Standard e3D heater has a plug and socket that is supposed to go behnd the heater block, but on the Mk3S, it gets in the way of the X carriage plastic piece) so go to the Prusa Specific Spares section on the e3d online website and get one without the connector
e3d resellers
Ebay,
Aliexpress,
Banggood
Amazon
REgards Joan
Opublikowany : 24/07/2020 11:37 pm
greg_abram
(@greg_abram)
Exactly what I needed to know - thank you!
Opublikowany : 24/07/2020 11:45 pm
