"Honking" X (or Y or Z) Axis
Hello,
One of my axis when doing sudden (or so it appears) movements has started recently making a loud "honking" noise. It isn't constant with all movements, but often enough to be disturbing. Oddly enough, it doesn't happen in stealth mode.....
Any ideas?
Thanks,
--Phil
Veröffentlicht : 24/04/2020 6:30 pm
RE: "Honking" X (or Y or Z) Axis
Hi Phil,
Have you checked everything is tightened,
is the Y motor rattling against the frame?
does the Y axis move smoothly?
If it's honking and you put a finger on the build plate, does the noise stop?
If you slow the feed rate, does the noise stop?
Veröffentlicht : 24/04/2020 6:56 pm
