Help! Y axis problem - resistance every 5 inches if I move bed back/forth
[Solved] Help! Y axis problem - resistance every 5 inches if I move bed back/forth
Crab
 Crab
(@crab)
My Y axis is binding up.. here is symptom.. I removed the bottom Y belt and I can move the bed smoothly.. But if I connect belt up, I get resistance every 4-5 inches.. which I think represents the shaft turn in the Y stepper motor.. I'm wondering what type of problem I'm having.. Is this a symptom of Y stepper motor failure?
I was getting some Y crashes and noticed this issue..  I removed the pulley at the LCD end and removed the belt from the Y motor pulley.. turned the pulley by hand.. but could feel no problem.. But when I re-attach belt to pulley and put some tension on it and move bed, I feel that odd resistance every 5 inches or so.. Nothing binding I can see..
Anyone experienced this?
Best Answer by Crab:
My issue.. I adjusted pulley last night too close to motor and pulley was binding on motor body
Napsal : 25/08/2022 7:54 pm
Crab
 Crab
(@crab)
RE: Help! Y axis problem - resistance every 5 inches if I move bed back/forth
Napsal : 25/08/2022 8:26 pm
