Help with noise and vibration MK3S
Hello everyone.
I have been wondering if someone could help me understand how to fix the high noise and vibration of the printer. It can be heard/felt in the common stairs outside the apartment...
The printer was assembled by me from a kit back in like 2020, and although it was never silent, it used to be mostly quiet. But it feels like it's getting worse with time. I recently cleaned and re-greased the bearings, rods, screws, and am using some custom larger feet I found online, as well as TPU bearing/bed holders. I also am using a custom Y-axis mount piece that keeps the motor separate from the frame to avoid further vibration (hasn't helped). As you can see in the video, both the X and Y axes are noisy.
Absolutely any help would be appreciated. It's come to a point that the noise/vibration are almost headache inducing.
There was supposed to be a video up there, trying here a second time!
https://youtube.com/shorts/3g6FSgE20Bw?feature=share
RE: Help with noise and vibration MK3S
there was a video, but is had some formatting data wrapped around it, which was stopping the forum displaying the link.
I have removed the formatting information, which seems to display a different URL, Hopefully one of the URL's will be satisfactory!
Thanks very much JoanTabb. In the meantime I also added a youtube link.
Hello
I had a similar issue with my MK3S+ i got since 2/3 weeks now.
To avoid it, or rather reduce it a lot , I used this feet : Snap-on squash ball foot for Prusa I3, or rather this one slightly higher Squash ball foot brackets 5" higher
Thanks for the suggestion! I'll definitely give that a try. Ordering some squash balls tonight! Did you do anything else at all?
Try to get the squash balls with two yellow dots as shown in the photo by @Lakwell. They have the highest dampening.
Absolutely nothing more.
It reduced the noise for sure
Will do, thanks! I'll make sure to post an update once it's done.
Sounds good, I'll give it a try and post the result!
Hi again!
So, the balls did make a huge difference, thank you for suggesting it! It didn't become completely quite but pretty much back to an acceptable range.
However, I upgraded to the MK3.5S in the meantime, and it became even more silent, but perhaps because of the increase in speed/acceleration causing less vibration overall. The sound tone of moving axes is completely different too, now being a lot more "electronic" rather than the "mechanical" from before.
Unfortunately, now I have layer shifts and the LCD seems bad, but that's another story! ahah
Cool
on my side , I will upgrade to klipper , which seems to improve printing quality
