Help - PEI ripped, peeled from smooth sheet.
Fynlcut
(@fynlcut)
 I have had my printer for about a month now.
 I recently printed a large lithophane box.  It finished around 10:30 PM, and around 6ish AM I wen to pop it off the sheet.
Now the sheet and print was room temperature. I flexed the sheet to break the print loose, but when I lifted it off, I saw it had pulled some of the PEI off. It actually ripped and separated as you can see.
Now after a few prints on the other side, the lifted parts look to have mostly glued themselves back down, but that ripped area is still ripped.
1 - OMG I broke it!
2 - Any thoughts on why that happened?
3 - Is it going to be an issue?
Veröffentlicht : 08/02/2021 1:22 pm
jsw
 jsw
(@jsw)
RE: Help - PEI ripped, peeled from smooth sheet.
What kind of filament?
I learned the hard way to always use a release agent with large flat ABS prints, and I always do as well with PETg and sometimes PLA, but usually PLA breaks free easily with no pulling of the coating.
Veröffentlicht : 08/02/2021 2:24 pm
Fynlcut
(@fynlcut)
I was using PLA, so I didn't use any release agent.
Nozzle was at 195C, bed was at 60C, so no odd temperatures during the print. Everything was at room temp when I removed it ~ 20.
Veröffentlicht : 08/02/2021 3:02 pm
Jgarrettg
(@jgarrettg)
I had the same thing happen to me on a PETG print.  That stuff sticks really well.  It was a small print too.  Brand new print bed.  Time to replace the PEI sheet.  Curious what kind of release agent jsw is using?
Veröffentlicht : 21/02/2021 5:05 pm
Jgarrettg
(@jgarrettg)
@jsw
What kind of release agent are you using?  Haven't heard of that before.
Thanks.
Veröffentlicht : 21/02/2021 5:07 pm
Dan Rogers
(@dan-rogers)
BTW, you can go a long time with a 1 sided PEI sheet - just be careful of those overly-sticky filaments.  I'd suggest you found one in PLA that will need a release agent.    By the way, if you are logged in on the prusa shop, you can find replacement PEI coating in the spare parts section.  I have a few on my shelf that I plan on using to fix up TWO smooth PEI sheets that I ruined before learning my lesson about release agents.
Veröffentlicht : 22/02/2021 7:43 pm
jsw
 jsw
(@jsw)
Posted by: @jgarrettg
@jsw
Thanks.
I use the Layerneer Bed Weld.  Amazon stocks it here in the States.  It works as both an adhesion booster and a release agent.  A little goes a long way.  I ordered a second bottle after I realized it was doing what I want, but I'm still on the first one.
Veröffentlicht : 22/02/2021 8:00 pm
Mitglied
@jsw
I concur.  Good stuff.  I am not so sure this isn’t similar to hair spray.
Veröffentlicht : 22/02/2021 8:41 pm
jsw
 jsw
(@jsw)
Posted by: @cwbullet
@jsw
On one of the other boards (Reprapper?) somebody said that this stuff may indeed be rebranded hair spray.  I've been meaning to do a sniff test against my wife's collection of hair products but have not gotten around to it.
Veröffentlicht : 22/02/2021 9:24 pm
Clarmrrsn
(@clarmrrsn)
@jsw
I could not do a sniff test with hair spray.
Makes me sneeze like nothing else 😀
Thankfully I have no hair to spray it on.
Tank you very much!
Veröffentlicht : 23/02/2021 12:34 am
Jeggo
(@jeggo)
Printing PETG on an smooth PEI bed seems to work better (release), when you clean the cold bed with IP alcohol.
I do this every second/third print. So far it work quite good. This first side of my PEI sheet I ruined the same way. The second side is so far ok.
Veröffentlicht : 23/02/2021 8:41 am
