Heatsink, Hotend, and Tips.
Switch626
(@switch626)
Hello everyone,
I started to get birds nests of filaments recently so I thought I would change the tip. I followed the instructions - 285 degrees, 45 degree turn on hot end, install tip, etc. I found the heatsink was very lose and could turn it about three times (900 degrees) before it seated. Now the tip will not seat the approximate 0.5mm specified. Is there a space for the heat sink above the heater block that must be maintained?
Thanks, Norman
Publié : 07/12/2020 11:20 pm
