Heater cartridge does not go on, 0 volt measured
mathijstk
(@mathijstk)
Hi all,
Problem: My heater cartridge does not work anymore. When putting the printer on preheat, I measure a voltage on the pins of 0 volt.
Context: Last week I broke of the heater cartridge when replacing the nozzle, I ordered a complete new nozzle-set and installed it. All worked fine so I started to make a print with my 1mm nozzle. After printing for one hour it gave a preheat error, and the cartridge did not heat up anymore. I ordered a new cartridge, did not work, measured the voltage, 0 volt.
When I look at the board there is a bright red LED on just next to the 15A fuse, is that normal? The heatbed works fine.
Anybody an idea how i fix this?
Respondido : 13/07/2020 7:18 am
mathijstk
(@mathijstk)
RE: Heater cartridge does not go on, 0 volt measured
Ah de 15 A fuse was intact, but i found that one of the 5A fuses was broken. Think replacing that one will solve the problem
Respondido : 16/07/2020 7:50 am
Posted by: @mathijstk
Hi all,
Regarding "preheat error" you will find some information (possible causes) on these sites:
https://www.help.prusa3d.com/en/article/preheat-error_2163
Respondido : 16/07/2020 8:33 am
