Heater cartridge does not go on, 0 volt measured
Hi all,
Problem: My heater cartridge does not work anymore. When putting the printer on preheat, I measure a voltage on the pins of 0 volt.
Context: Last week I broke of the heater cartridge when replacing the nozzle, I ordered a complete new nozzle-set and installed it. All worked fine so I started to make a print with my 1mm nozzle. After printing for one hour it gave a preheat error, and the cartridge did not heat up anymore. I ordered a new cartridge, did not work, measured the voltage, 0 volt.
When I look at the board there is a bright red LED on just next to the 15A fuse, is that normal? The heatbed works fine.
Anybody an idea how i fix this?
RE: Heater cartridge does not go on, 0 volt measured
Ah de 15 A fuse was intact, but i found that one of the 5A fuses was broken. Think replacing that one will solve the problem
Hi all,
Regarding "preheat error" you will find some information (possible causes) on these sites:
https://www.help.prusa3d.com/en/article/preheat-error_2163
