Heatbed not heating
My heatbed doesn't heat up anymore. When the heatbed is not plugged in in the heatbed output connector on the RAMBo, LED6 goes on when I ask the printer to heat the heatbed. But I messure les than 6 V between the pins of the output. when i plug the heatbed in LED6 goes out en I mesure 0V between the pins.
Veröffentlicht : 21/06/2018 8:32 am
Re: Heatbed not heating
sounds like you need to talk to support and get a new board.
Veröffentlicht : 21/06/2018 11:07 pm
