Heatbed cable assembly problem
patsoffice
(@patsoffice)
Hello,
I had the heatbed cable assembly have a bit of a thermal problem that completely melted the cover and likely caused some problems with the heatbed. Will order a replacement, but was curious if anybody has any thoughts what could have happened here as things have been working fine for months.
Respondido : 05/03/2021 8:06 pm
patsoffice
(@patsoffice)
RE: Heatbed cable assembly problem
And... I should have searched before posting. https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heatbed-cable-melted-down/#post-209430 had the same problem.
Additionally, I'm possibly a moron and it looks like I assembled it incorrectly in the same way as the poster above did. 🙂
Respondido : 05/03/2021 8:11 pm
Dan Rogers
(@dan-rogers)
lessons learned. Those screws need to be tightened down well.  A little bit of loose and you'll get burning and too much heat.  Glad you found out without any great damage.
Respondido : 07/03/2021 9:35 pm
1 les gusta
Clarmrrsn
(@clarmrrsn)
Nasty one, I echo Dan's sentiments.  Glad you found it in time.
Loose connections on cables can be very nasty if left for extended periods.
Saw it a few times at work with engineers who are a bit lazy, nearly set a huge M/C on fire with loose connections onto very heavy duty 24v lines.
Tank you very much!
Respondido : 08/03/2021 1:26 pm
Miembro
@dan-rogers
And check them often, they can loosen.
Respondido : 08/03/2021 1:46 pm
Clarmrrsn
(@clarmrrsn)
Posted by: @cwbullet
@dan-rogers
Have these connections got star washers on them or is that just normal washers I see?
I know sometimes these are frowned upon, but certainly stop loosening
Esta publicación ha sido modificada el hace 5 years por Clarmrrsn
Tank you very much!
Respondido : 08/03/2021 2:26 pm
