Get a tight bore from a stl file
jlcapel
(@jlcapel)
Hello,
I print the original part "x-end-motor.stl" of the prusa MK2S but in output the bore (hole) to receive the bearings is too fair (not enough tight). I got the STL file from the Prusa3d website. Is it possible from a cutting software (Simplify3d or PrusaSlicer) to play on a parameter to obtain a smaller bore?
Thank you for your advice
Greetings
Jean-Luc
Respondido : 03/11/2019 10:21 am
Zoltan
(@zoltan)
Miembro Moderator
RE: Get a tight bore from a stl file
In PrusSlicer you can only play with the scale,which is changing the whole model scale (in different axes) but not parts of it. For changing the hole size you have to use 3D design tool or create a cylinder with hole of desired diameter and merge your part with that cylinder  via PrusaSlicer.
Respondido : 03/11/2019 11:06 am
Suggest you print a 50 mm object and verify your printer is calibrated. If not, run the XYZ calibration again and then recheck.
Respondido : 03/11/2019 7:53 pm
