gcode to warm up enclose before printing
islander2013
(@islander2013)
On my voron (klipper) i have code which heats up the chamber until a certain temp, and I wanted to know if its possible on my mk3s (marlin) too.
Basically in the winter/spring it gets too cold and it gets the mintemp error a lot. I wanted to see if i can lower the mintemp (to get rid of that error) and also just use the heat from the bed to at least get the temp up a little before i start printing for the day.
Its a pain having to hold a hairdryer in the enclose until it reaches a certain temp! any thoughts?
Opublikowany : 22/03/2023 4:10 pm
The easiest way is to include a simple dwell time code in the gcode startsequence (set G4 after M190):
M190 R[first_layer_bed_temperature] ; wait for bed temp
G4 S1200 ; wait and heat bed for 20 minutes
continue rest of code...
wbr,
Karl
Opublikowany : 22/03/2023 4:25 pm
RE: gcode to warm up enclose before printing
PrusaSlicer expert settings:
wbr,
Karl
Opublikowany : 22/03/2023 4:30 pm
islander2013
(@islander2013)
thanks dude, most appreciated! just wish the prusa discord was more popular and had the same community as the forum.
Opublikowany : 24/03/2023 7:51 pm
