G1 Z0.1 command not possible
Oscar88
(@oscar88)
When enter G1 z0.1 command, lcd still  display Z is 0.15
Is that  a security feature ?
Postato : 07/09/2019 8:04 am
RE: G1 Z0.1 command not possible
Not security so much as safety. You can't get the nozzle lower than 0.15mm with move commands. I recall seeing a software endstop message on the serial console while experimenting with this once. There are ways around this if you want to drive the nozzle into the print surface, but this helps prevent  inadvertently doing so.
Postato : 07/09/2019 3:12 pm
Oscar88
(@oscar88)
Ok it’s for safety
There is a gcode command « M211 S0 » to deactivate endstops, is it working for Prusa ?
Postato : 07/09/2019 6:04 pm
What are you trying to do?
Postato : 07/09/2019 9:32 pm
And the MK3 has physical end stops, so disabling them buys you nothing.
Postato : 08/09/2019 2:10 am
