G-Code for filament retraction
Ira S
(@ira-s)
Whenever I finish a print and go back and start another print, some filament oozes out of the nozzle while the extruder is pre-heating. Once pre-heating is done, I wipe it off, but I have to watch and be sure to do this or the string of filament winds up as part of the print somewhere.
I'd like to add a command in Printer Settings, Custom G-Code, End G-Code to retract the filament 3mm or so automatically at the end of each print. On my previous printer that seemed to take care of the problem. And, given that the MK3 does an initial extrude strip to insure filament is flowing, the retraction won't hurt anything.
Can someone tell me what the G-Code would be to retract 3mm of filament (relative).
Thanks.
Postato : 17/10/2018 12:03 am
33edc
(@33edc)
Re: G-Code for filament retraction
I see this is very old, I would also like to find some information about this issue.
Postato : 03/02/2019 12:45 am
Ira S
(@ira-s)
I added the following and it works very well
In Printer Settings, Custom G-Code, in the End G-Code block, just above the M84 line
M83 ; set to relative
G1 E-4 F900 ; retract 4mm at 15mm/sec
Postato : 03/02/2019 1:07 am
2 persone hanno apprezzato
33edc
(@33edc)
RE: G-Code for filament retraction
Posted by: ira.s3
Thank You! Worked as I was hoping.   I still wish Prusa would add this to Slicer as an advanced setting option with warnings like they have on their other settings.
Postato : 21/07/2019 12:28 am
TeeBell
(@teebell)
What do you do when you change filament before a print? It would not have done a retraction before you start the next print.
Posted by: @ira-s
Postato : 14/06/2022 5:52 pm
Rob Ludwick
(@rob-ludwick)
@TeeBell
If you're changing filament by hand you can run the extruder (E-Axis) forward a few mm.  Pull off the extruded plastic, then roll back the extruder.
Settings -> Move Axis -> Extruder.
Postato : 18/09/2022 9:17 pm
CatEye
(@cateye)
Thank you. Worked well.
Posted by: @ira-s
Postato : 16/07/2023 9:10 pm
