FW update bug: "model was sliced for another printer model"
Leo M
(@leo-m)
After updating my MK3S and MMU2S (with MK3S_MK3S+_FW_3.14.1_MULTILANG.hex and respective MMU2S_MMU3_FW3.0.3+896.hex), my printer displays this error message "model was sliced for another printer model" every time I try to print a model (sliced correctly using PrusaSlicer 2.9.0).
I verified the gcode in subject and it contains the correct printer model check: "M862.3 P "MK3SMMU2S"
So, the only logical issue remaining is that the printer is now looking to find a different string at the printer model check in the gcode.
Finally, the questions I have are:
1. What is the updated printer firmware looking for to find in the gcode when it does the printer model check?
2. How do I properly fix this issue? (hopefully without removing the printer model check from the original printer start gcode)
3. Does Prusa have any plans to fix this bug?
Opublikowany : 10/01/2025 8:28 pm
ChristiePrints
(@christieprints)
RE: FW update bug: "model was sliced for another printer model"
I am also having this issue since installing 3.14.x - I have not changed anything on my slicer only updated the firmware to the printer.
Any thoughts @Pruse3d?
Opublikowany : 08/02/2025 2:24 pm
Whohastimeforthis
(@whohastimeforthis)
Same here.  "G-Code Sliced for a different printer".
Opublikowany : 01/03/2025 12:31 am
Kahnindustries
(@kahnindustries)
Same!
I only updated to get rid of the version number warning, now i get "model was sliced for another printer model" before every print
GCODE has
M862.3 P "MK3SMMU2S" ; printer model check
Printer lists MK3s as the printer and MMU active
Print works normally after accepting the message
I print via octoprint, so having to go click ok on the printer is very annoying!
Opublikowany : 19/03/2025 8:45 am
