FW 3.9 Tone timer re-enabled (How to set?)
The function responsible for the tone playback was broken in the previous release. It is now fixed and available at timer4 (timer2 is used as a system_timer) both for Einsy (MK3S/MK3) and MiniRambo (MK2.5S/MK2.5).
How do you set this? When I used to own a MK2.5 I used to play a ring tone when the print was complete. Is there a way to enable this again?
Veröffentlicht : 29/05/2020 11:22 pm
RE: FW 3.9 Tone timer re-enabled (How to set?)
Hello enzo-m
I don't know for 3.8.1, I'll not go back to check, but in 3.9.0 it is working, you have to add M300 at end-gcode (printer parameters), you can download thousand of 'gcode music' here in a zip.
(you can just add M300 lines into a dedicated file music.gcode (for example) and read it with the printer to test it)
Enjoy.
MK3S & Fusion 360
Veröffentlicht : 31/05/2020 8:39 pm
