Fusion 360 with Slic3r or PrusaSlicer
Cowasaki
(@cowasaki)
Is anyone using these without a mid step?  The only way I can design it Fusion 360 and print using Slic3r has been to select the object and select "3d print" in Fusion which then only allows me to output to certain programs, one being Cura.  Once output to Cura I then export as an ASCII STL file and then drag and drop into Slic3r.
This topic was modified před 7 years by Cowasaki
Napsal : 05/06/2019 3:40 pm
vintagepc
(@vintagepc)
RE: Fusion 360 with Slic3r or PrusaSlicer
Untick the option of sending it to a program and it will prompt you to save an STL instead.
Napsal : 05/06/2019 3:46 pm
Lichtjaeger
(@lichtjaeger)
Choose "custom" as the print utility. Then click on the folder icon that shows up. Search in your computer for "prusa-slicer.exe". Voil la, it works.
On Windows, you will find the file usually at C:\Program Files\Prusa3D\PrusaSlicer.
Napsal : 05/06/2019 5:56 pm
1 lidem se líbí
Cowasaki
(@cowasaki)
Thanks.  That's brilliant, I can now go straight to Slicer
Napsal : 05/06/2019 7:10 pm
