from Prusa Bear to Prusa standard?
ManelTo
(@manelto)
Has anyone returned from Prusa Bear to the original Prusa? Why? I have my doubts. Maybe I'm bored. I've never seen a printing advantage with the Bear layout, but I think it takes the printer away from the periodic improvements, updates, or changes introduced by Prusa.
Sorry for my poor English. I try to do my best.
Opublikowany : 18/01/2022 10:26 am
RE: from Prusa Bear to Prusa standard?
Doubts?  Doubts that it can be done or Doubts that you can do it?
Opublikowany : 18/01/2022 11:53 am
ManelTo
(@manelto)
Doubts about whether it is worth doin.
Posted by: @cwbullet
Opublikowany : 18/01/2022 12:45 pm
If you want to readily update to future versions, then it migth be worth it.  If not, I would nto worry about it.
Opublikowany : 18/01/2022 5:41 pm
ManelTo
(@manelto)
I think you have multiple printers. Do you have a Prusa Bear? If so, any difference in print quality from the original?
Thanks in advance
Opublikowany : 19/01/2022 7:00 am
Once you have them dialed in, I see no difference.  I have one Bear that I have upgraded.  It started with V6 and now has a Mosquito Magnum with Bondtech.  I also have a Mk3S+ with a Dragon, MK3S with Magnum and Bondtech, and 6 more Mk3S+ with e3D V6.  Many started as MK3 or earlier variants and were upgraded.
To me, the Bear is more about looks.  It may be stiffer, but that did not translate to a huge jump in quality for me.
Posted by: @manelto
Thanks in advance
Opublikowany : 19/01/2022 11:05 am
