Flash firmware from SD-Card Directly?
jbudding
(@jbudding)
Is there a way to update the firmware by copying the firmware file to the SD Card and clicking on it?  I really really really don't want to have to attach a USB cable from my PC all the way to where I have the printer setup.  The distance is very long to where I have the printer setup, and it would be a real pain to move it.
Best Answer by bobstro:
Posted by: @towlerg
OctoPrint. Great if your printer is not near your PC. It will can use either WiFi or wired Ethernet and I believe there is a plugin for flashing printer firmware.
Yes, and it works quite well! It has made keeping my printers updated much simpler.
Publié : 21/01/2021 12:27 am
richnormand
(@richnormand)
RE: Flash firmware from SD-Card Directly?
Friend with a laptop?
REPAIR, RENEW, REUSE, RECYCLE, REBUILD, REDUCE, RECOVER, REPURPOSE, RESTORE
Publié : 21/01/2021 3:46 am
towlerg
(@towlerg)
Publié : 21/01/2021 9:30 am
1 personnes ont aimé
Cynan
(@cynan)
You need a computer connected, be it a laptop or Pi I'm afraid.
Publié : 21/01/2021 4:25 pm
Posted by: @towlerg
Publié : 21/01/2021 6:14 pm
ManelTo
(@manelto)
For me the Toshiba Flash Air SD is perfect.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../flashair-wifi-sd-card-setup-and-drive-mapping/
Sorry for my poor English. I try to do my best.
Publié : 21/01/2021 7:00 pm
Cynan
(@cynan)
I use a FlashAir as well, however it won’t let you flash the printers firmware.
Publié : 21/01/2021 7:48 pm
jbudding
(@jbudding)
@bobstro
If OctoPrint can flash the firmware then I am definitely buying the Raspberry Pi Zero W attachment.
Publié : 22/01/2021 1:05 am
OctoPrint will definitely do the job, but I'd recommend against using a RPi Zero. The OctoPrint developer specifically says the Zero is not recommended or supported.
Publié : 22/01/2021 2:02 am
towlerg
(@towlerg)
Echo bobstro, Zero is no longer fit for purpose. Get either 3B+ or 4 (pretty much same price here). I wonder if there is some way to get Prusa to remove instruction to install Zero? Anyone got any clout with Prusa?
Ce message a été modifié il y a 5 years par towlerg
Publié : 22/01/2021 11:15 am
