Firmware version mismatch
dameion.d
(@dameion-d)
So, I updated my i3 MK3S printer to the newest firmware, and am having an annoying issue.
I went to the the site [ https://help.prusa3d.com/downloads#mk3 ]
Selected my printer: ORIGINAL PRUSA I3 MK3S
And what I wanted to down load: FIRMWARE 3.12.0
This gives me a compresses file: prusa3d_fw_3_12_0_MK3S.zip
And when I unpack it I get: prusa3d_fw_MK3S_MK3S+_3_12_0_5672.hex (note the "+" in there)
Now every time I print I get the message "G-Code sliced for a different printer type. Continue?"
Where is the MK3S hex file, not the MK3S+?
I doubt it, but is there a way to modify the hex file to correct the printer name?
Napsal : 17/01/2023 11:06 pm
RE: Firmware version mismatch
These lines in the Custom Gcode, Start Gcode Notify Model, nosel size and latest firmware
M862.3 P "[printer_model]" ; printer model check
M862.1 P[nozzle_diameter] ; nozzle diameter check
M115 U3.11.0 ; tell printer latest fw version
Napsal : 17/01/2023 11:42 pm
dameion.d
(@dameion-d)
Thanks. That is a option for when making new g-code (or just change the printer model in the slicer), but does not work for all the currently sliced files.
I really need a way for the printer to just be the correct printer model.
Napsal : 18/01/2023 1:52 pm
have you tried ignoring the wrong printer message?
the print should pause a while, then continue.
If the printer has not been upgraded to a new fomat, say mk3 to mk3S+
then Mk3 gcodes should run on a mk3 machine without 'printer type' error
I have a number of printers,
I I create gcode for my mk3, it will run on my mk3S but i do get an error message  (And Vice Versa)
sometimes people load the incorrect version of firmware when they upgrade, this can cause printer type errors to be reported.
If you have recently updated your firmware, I would suggest you download another copy, making sure that it is for your printer type, and re load your firmware, lthen test to see if the message appears again!
Napsal : 18/01/2023 2:01 pm
dameion.d
(@dameion-d)
did not know that, thanks.
I checked the version twice because I though the same. But it is from the prusa3d_fw_3_12_0_MK3S.zip file which is the download link for the ORIGINAL PRUSA I3 MK3S and the ORIGINAL PRUSA I3 MK3S+ on the page.
Thanks for the help
Napsal : 18/01/2023 11:46 pm
