Firmware update scrambled CRASH DETECTION
jandb150
(@jandb150)
Im wondering if anyone else has had this happen, since the latest FirmWare update, I started getting Crash Detection issues in the middle of bed level calibration checks prior to printing anything. Of course at first, I check all the things that PRUSA suggest, which all checks out to the best of my knowledge. It trips CT  in the same spot and round count as it counts down the  points on the bed. Sometimes after it resets itself it has worked through it and prints fine, other it times out and throws an ERROR on the screen. I simply turned that feature off and its gtg now, but I'm curious if anyone else has had this happen and if there is a fix or patch yet?
Postato : 20/12/2023 12:53 pm
OgiLee
(@ogilee)
Utenti
RE: Firmware update scrambled CRASH DETECTION
I have started to get the same issue, also i try self test and its stops on fan check and after manually say that is spining it continue with calibration, everything was done succesfully but still i get the crash detection on randome places on the print
Postato : 20/12/2023 7:10 pm
jandb150
(@jandb150)
Its slightly more comforting knowing I'm not the only one, BUT surely they are aware of this no? Is there any way to submit this issue to PRUSA to see if they have a patch possibly? Not that its too critical bc I just work around it by turning off CT from the settings panel.
Postato : 21/12/2023 2:59 am
