Firmware Update Issues for MK3S+ and MMU2S
hattrekker
(@hattrekker)
I am new to 3d printing and have enjoyed using my printer. I am still trying to figure out the MMU2S, and have been printing using PETG. I was on the following firmware for my printer: prusa3d_fw_3_12_2_MK3S and on the following firmware for my MMU2S: prusa3d_fw_3_12_2_MK3S_1_0_6_MMU2S. I don't print a lot of things, but I decided to switch out my PETG filament for PLA. While I was doing that, I also did a firmware update for printer and MMU. I have updated using the following hex files: Printer - prusa3d_fw_MK3S_MK3S+_3_13_1_6876.hex and MMU - prusa3d_fw_MMU3_3_0_0.hex
When I did this update, I was unable to get my MMU unit to find home. It kept giving an error message. I tried troubleshooting numerous times, but eventually just removed the mmu unit temporarily and turned it off in the menu. I tried running the printer without the mmu, the filament would load into the extruder and I could print a bit, then it would continue printing without having any filament go through the extruder. I tried cleaning the nozzle and doing a cold pull, but it didn't seem to help at all. I am wondering if anyone has any suggestions.
Napsal : 16/10/2023 1:30 am
James AZ
(@james-az)
RE: Firmware Update Issues for MK3S+ and MMU2S
After updating to 3.13.1, I get the message that:  "G-code sliced for a different printer" and the MMU2 fails to respond at all.
Napsal : 19/10/2023 10:10 pm
1 lidem se líbí
Hello
(@hello)
If you updates the mmu firmware in the slicer you need to select mmu3 even though you have mmu2
Posted by: @james-az
Napsal : 19/10/2023 11:04 pm
Alfanero
(@alfanero)
In this firmware version you have to switch on the MMU2S in the Settings menu
Napsal : 22/10/2023 1:12 pm
MomoJojo85
(@momojojo85)
I think this fixed my issue! I know there are a lot of combinations of printers and MMUs, but this REALLY should have been called out somewhere (and the Thermal Calibration too).
Napsal : 29/10/2023 6:38 pm
