Firmware Update failed from prusa3d_fw_3_11_0_MK3S.zip
i wanted to upgrade the firmware from 3.10.1 to the latest version using prusaslicer and i get the following error:
invalid record at line 74 of "/Users/ralfzimmerningkat/Downloads/prusa3d_fw_3_11_0_MK3S.zip"
any idea?
Ralf
vrdude-slic3r -v -p atmega2560 -c wiring -P /dev/cu.usbmodem14101 -b 115200 -D -U flash:w:0:/Users/ralfzimmerningkat/Downloads/prusa3d_fw_3_11_0_MK3S.zip:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Sep 6 2022 at 09:19:15
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : /dev/cu.usbmodem14101
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0,0 V
SCK period : 0,1 us
avrdude-slic3r: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0,01s
avrdude-slic3r: Device signature = 0x1e9801 (probably m2560)
avrdude-slic3r: reading input file "/Users/ralfzimmerningkat/Downloads/prusa3d_fw_3_11_0_MK3S.zip"
avrdude-slic3r: invalid record at line 74 of "/Users/ralfzimmerningkat/Downloads/prusa3d_fw_3_11_0_MK3S.zip"
avrdude-slic3r: read from file '/Users/ralfzimmerningkat/Downloads/prusa3d_fw_3_11_0_MK3S.zip' failed
avrdude-slic3r done. Thank you.
Respondido : 04/01/2023 7:44 am
Looks like you chose the zip file follow this exactly https://help.prusa3d.com/article/firmware-updating-mk3s-mk3s-mk3_2227
Respondido : 04/01/2023 8:31 pm
Topic starter
answered:
RE: Firmware Update failed from prusa3d_fw_3_11_0_MK3S.zip
thanks for the tip.
anyone who can read is clearly at an advantage.
it has now worked
Respondido : 05/01/2023 8:17 am
At least now it works
Respondido : 05/01/2023 9:28 am
