Firmware crash when loading from SD while also loading from filament
enrico.gueli
(@enrico-gueli)
Hi all,
sometimes I see my MK3S crashing its firmware. Luckily this happened before printing so nothing is lost. It happened for the third time, but this time I think I recall the steps to reproduce, and I also have a memory dump.
In short, it seems to be happening when the firmware wants to show the dialog "is the filament color correct?" while also loading a gcode file from the SD card i.e. when the progress bar is visible.
Steps:
  1. Turn on the printer, with an SD card inserted and at least one gcode file. The larger the file, the better.
  2. Unload any filament if present
  3. Load a filament
  4. Select the large gcode file.
  5. If the timing is right, the printer will crash right away and displays the message "firmware crash detected" etc.
I've managed to produce a crash dump file, I attached it here: crashdump_loadload
Not sure if it helps, but I also have a memory dump fresh after a reset: crashdump_after_reset
While trying again, the firmware crashed one more time. This time I don't remember what was I doing, but I wasn't messing around with the filament, so this crash dump may be unrelated: crashdump_another (this one has two dumps, don´t remember if I just typed D21 twice or it's two different crashes)
This happened with firmware 3.10.1-4697, so not the latest firmware. I don't know if the related bug has been fixed already.
The workaround is simple: just wait until the filament extrudes with the correct color before choosing something to print.
Hope that helps.
Cheers!
Opublikowany : 13/08/2022 12:43 pm
