Firmware 3.3.0 for Original Prusa i3 MK3
Página 4 / 5
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
Re: Firmware 3.3.0 for Original Prusa i3 MK3
Hi RetireeJay,
this is a very strange behaviour. I've flashed 3.3.0 to several printers and no issues at all. Are you running stock parts, or do you have some mod? Ideally please start an issue at GitHub to alert the devs: https://github.com/prusa3d/Prusa-Firmware/issues
Assembly manuals
/ Knowledge Base
Respondido : 12/07/2018 9:49 am
RetireeJay
(@retireejay)
Well, the problem is solved in one sense, but quite mystifying in another. I had previously modified the source code to compile my firmware with bang-bang control for the bed heat. This time, I had failed to make that modification. It turns out that apparently once you have implemented bang-bang control of the bed heat, there's a bit set somewhere that does not get reset when you upload firmware that uses PID control for the bed, making PID control fail. I tried using the "factory" versions 3.3.0, 3.2.1, 3.2.0, 3.1.3, and 3.1.1 and none of them would heat the bed. But once I commented a single line in Configuration_Prusa.h (line 432 //#define PIDTEMPBED), the bed started behaving normally. I will raise this as an issue on GitHub.
Respondido : 12/07/2018 4:57 pm
Neikius
(@neikius)
Supposedly failed, looks like it might be OK? Printer says it is on v3.3
avrdude: Version 6.3-20160220-prusa3d, compiled on Jul 5 2018 at 15:47:40
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/nejc/Programi/Slic3rPE-1.40.1+linux64-full-201807051330/resources/avrdude/avrdude.conf"
Using Port : /dev/ttyACM1
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: safemode: hfuse reads as D0
avrdude: safemode: efuse reads as FD
avrdude: reading input file "/home/nejc/Prejemi/prusa3d_fw_MK3_3_3_0.hex"
avrdude: writing flash (253106 bytes):
Writing | ################################################## | 100% 44.48s
avrdude: 253106 bytes of flash written
avrdude: verifying flash memory against /home/nejc/Prejemi/prusa3d_fw_MK3_3_3_0.hex:
avrdude: load data flash data from input file /home/nejc/Prejemi/prusa3d_fw_MK3_3_3_0.hex:
avrdude: input file /home/nejc/Prejemi/prusa3d_fw_MK3_3_3_0.hex contains 253106 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 32.43s
avrdude: verifying ...
avrdude: 253106 bytes of flash verified
avrdude: safemode: Fuses OK (E:FD, H:D0, L:FF)
avrdude done. Thank you.
Using Programmer : arduino
avrdude: prusa_init_external_flash(): MK3 printer emitted incorrect cfm code: `echo: 3.3.0-8`
avrdude: arduino_open(): Failed to initialize MK3 external flash programming mode
Tried 3.2.1 now, the output is a bit different, seems like 3.3 is trying to do something more and failing at it?
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: reading input file "/home/nejc/Prejemi/prusa3d_fw_MK3_3_2_1_576.hex"
avrdude: writing flash (249582 bytes):
Writing | ################################################## | 100% 43.33s
avrdude: 249582 bytes of flash written
avrdude: verifying flash memory against /home/nejc/Prejemi/prusa3d_fw_MK3_3_2_1_576.hex:
avrdude: load data flash data from input file /home/nejc/Prejemi/prusa3d_fw_MK3_3_2_1_576.hex:
avrdude: input file /home/nejc/Prejemi/prusa3d_fw_MK3_3_2_1_576.hex contains 249582 bytes
Reading | ################################################## | 100% 31.97s
avrdude: 249582 bytes of flash verified
Respondido : 15/07/2018 6:38 pm
alexander.k28
(@alexander-k28)
I'm having the same issue with filament use not being recorded. Also, the statistics screen flashes and stutters during a print. Print time seems normal, however. Thanks for all your hard work, Prusa devs! Hope you guys can fix this issue soon.
Respondido : 16/07/2018 8:05 am
alain.d5
(@alain-d5)
Just upgraded to the latest firmware(3.3.0) and now, I cannot print without interruption !
1-SD card print: Printer just stop in the middle print showing no error.
2-Print with pronterface: Printer stops every 10 minutes with error code:
File "printrun\printcore.pyc", line 471,
in _print File "printrun\printcore.pyc", line 545,
in _sendnext File "printrun\printcore.pyc", line 567,
in _send MemoryError
Has resorted to downgrade firmware. Any clues ?
Respondido : 16/07/2018 7:52 pm
Pintie
(@pintie)
updated to 3.3.1
have display issues. no matter which language, there are blocks in some lines - not text....
Respondido : 17/07/2018 7:03 pm
moojuiceuk
(@moojuiceuk)
I've just gone from 3.3.0 to 3.3.1 and found the text on screen to be fine. Have you tried a full factory reset? (Hold dial down as printer is powered on, then release when you hear the BEEEP). Are both cables between screen and Einsy connected OK?
Respondido : 18/07/2018 8:01 pm
CybrSage
(@cybrsage)
After the upgrade to 3.3.1 from 3.3.0, all of my prints immediately started failing the bed level portion of the print. I went ahead and had it redo the Z axis calibration and then everything started working perfectly again. I physically changed nothing.
Just an FYI.
Respondido : 18/07/2018 10:03 pm
Pintie
(@pintie)
something went wron when flashing.
did it again - now the printer works better than ever before.
Respondido : 19/07/2018 8:29 am
DevDoc
(@devdoc)
Just an FYI.
That seems to be the best process lately and really doesn't take too much time for peace of mind. I think a lot of problems arising from these new firmware revisions would be resolved if a full wipe is performed.
Respondido : 19/07/2018 3:23 pm
DevDoc
(@devdoc)
Hi there,
new version of firmware 3.3.0 for MK3 and MK2.5 is out! This is a final version recommended to all MK3 and MK2.5 owners 😉
What is new:
MK3:
- recurring crash detection limit
- crash detection and filament runout detection improvements and bugfixes (focused on Octoprint and USB printing)
- fixed erroneous movements during stop print
- supports multiple languages
- M86 gcode for safety timer
- temperature calibration improvements
- power panic fix
- supports remaining time estimation provided from Slicer (support in the future versions of Slicer)
MK2.5:
- Filament runout detection fixes and improvements (focused on Octoprint and USB printing)
- different language variants
Supported printers:
This firmware supports Original Prusa i3 MK3 and MK2.5
Download link and description:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.3.0
Firmware flashing guide:
http://manual.prusa3d.com/Guide/Upgrading+firmware+v1.2/66?lang=en
Note: Use the latest Slic3r PE 1.40.1 to flash other languages for the MK3!!!
More in the changelog.
Please report any bug here:
As always, we wish you happy printing and look forward to your feedback!
Previous versions:
Hi there,
new version of firmware 3.3.0-RC1 for MK3 and MK2.5 is out! Note this is a test build for advanced users 😉
What is new:
MK3:
- power panic fix
MK2.5:
Supported printers:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.3.0-RC1
Note: Use the latest Slic3r PE 1.40.1-beta to flash other languages
Should this be updated as the link is directly to the 3.3.0 tag rather than the tip production release. I would guess many folks are quickly skimming and grabbing it without knowing that there is a later release.
Respondido : 19/07/2018 3:25 pm
ewr2san
(@ewr2san)
I have the same issue as bellow.
Slic3rPE-1.40.1+linux64-full flashing v3.3.1-845.
Fail messages at the:
avrdude: prusa_init_external_flash(): MK3 printer emitted incorrect cfm code: `echo: 3.3.1-8`
LCD shows 3.3.1-845, and it prints.
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Vtarget : 0.0 V
SCK period : 0.1 us
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Vtarget : 0.0 V
SCK period : 0.1 us
Respondido : 19/07/2018 8:25 pm
normhuntley@aol.com
(@normhuntleyaol-com)
I received my MK3 in February an assembled printer and had no issues printing out of the box, when new driver and firmware was installed had no problems installing, when I tried to use the layering I received error messages which said I had a windows driver missing also graphics card issue. My computer was 7 years old was a windows 7 updated to windows 10. My son had a new computer he uses to play games on, we installed Prusa software on it no problems, I bought a new computer. I have had no problems since.
I have been working with CNC equipment since 1973 the Construction Company I worked for bought 2 CNC for rebuilding heavy equipment under carriage parts they had 5 tool heads for the different operations, they where programed with punch cards and run with tape reels. No PC's in those days and no internet, if you had a problem long distance to Italy.
I wrote my first computer program in the early 1980's with Microsoft Basic which is a long way from today. I have a CNC I use to do wood work for 11 years.
We all are downloading the same software to run our Prusa printers some are having problems some are not. I work with computers 5 days a week and have seen every issue that you imagine, al lot of them are with drivers, my issue was a computer that needed driver update and a updated graphics card. If I was to see that I was having a problem and you are not and we have the same Prusa printer but we don't have the same computer, I would look at my computer real hard.
I own two knockoff printers that bought a year ago I put together myself that where a nightmare to set up and print. The Prusa MK3 prints are awesome, the only thing I change sometimes are the temperatures.
I have had no extrusion problems, I have had the power go off and when the printer restarts smooth as glass. I ordered the MM2 can't wait.
Josef keep doing what you do. I turned 80 in June and found out you are never too old to learn. thanks Norm
Respondido : 20/07/2018 7:55 pm
ed
 ed
(@ed-3)
But because yours is running fine and someone else's isn't doesn't preclude the possibility that there's an issue with the printer. However, you're correct in that one should always start with the basics... Is it plugged in?
Respondido : 20/07/2018 8:48 pm
normhuntley@aol.com
To clarify what I was getting to, if the downloaded drivers and firmware are not operating right, it could be the windows drivers need updated, it is what happened to me, also the printer not operating right could be that the printer is not calibrated correctly. I built two 3D printers from kits and found that if I wanted a proper print everything had to be correctly put together. When I started 3D printing I was lucky to have a person who works with 3D printing at an aerospace company he was a great help with the setup of the printer kits and the storing of the filament to keep it dry with desiccant packs in plastic bags, when I am printing I use a Polybox from Polymaker keeps the filament under 20% humidity the garage I was printing in had a humidity of 70% + that's Florida for you. The difference in a print with filament of 70+ % or less than 20% is like night and day. The CNC that I use for woodworking, the wood needs to be around 11% humidity. I know that there has been things that Prusa had to correct like not counting the filament etc. they react to them in a promptly.
Respondido : 21/07/2018 4:11 am
ed
 ed
(@ed-3)
Understood and agreed, at my previous employer and we started having all kinds of strange issues with our modeling software crashing and certain modules not working properly. After several reinstalls and and calls to the modeling software's support it turned out it was the updated Nvidia quadro driver that was causing the issues, oddly enough it was only happening on a few machines, in our case a video driver downgrade resolved the issue.
Respondido : 21/07/2018 1:34 pm
Tiago
(@tiago)
I got some problems after flash 3.3.1 firmware.
1) Can't move Z axis on LCD, the menu show but rotate the knob do nothing, lcd digits don't change. It start work after i print something from sdcard
2) Very slow print from octoprint, print constantly stop during some large seconds and then do the next step and keep doing that. Work just fine before the upgrade. Print from SDcard is OK.
Anyone have this problems?
Respondido : 21/07/2018 3:12 pm
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
UPDATE: Version 3.3.1 is out! https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64/firmware-3-3-1-for-original-prusa-i3-mk3-t23335.html#p99345
Assembly manuals
/ Knowledge Base
Respondido : 23/07/2018 12:51 pm
PrintingFun001
(@printingfun001)
RE: Firmware 3.3.0 for Original Prusa i3 MK3
I hope this is the best spot for this. This month I upgraded my i3 MK3 to MK3S with the new filament sensor. Everything is working great except that it will print (go through the motions) even when there is no filament in place. This happens in two instances that I've noticed. One is if I fail to properly feed in the filament after a color change and prematurely press the button in response to the question about whether the filament fed properly and the color is correct. It will just proceed merrily on printing air. Likewise, if it runs out of filament, it just continues. The first instance has happened a couple times and the second occurred during a specific test where I just cut the filament line to see what it would do.lk
After the upgrade, I checked/tested the filament sensor in the hardware settings area and it dutifully acknowledged the presence of filament when in place and noted its absence when it was gone. After the hardware update, I d/l the current firmware (3.13.2) and the latest PrusaSlicer 2.7. Everything has worked fine after the upgrade except this particular issue. Any insight would be appreciated.
Respondido : 12/12/2023 4:13 am
PrintingFun001
(@printingfun001)
Still hoping for some thoughts on this issue. I am concerned about leaving the printer on overnight and then running out of filament or having it break. Thanks again.
Respondido : 09/02/2024 6:19 am
Página 4 / 5
