firmware 3.10 error
manuel.r6
(@manuel-r6)
firmware 3.10 error
Estoy intentando instalar la version de firmware 3.10 y siempre obtengo el mismo resultado. Despues de acabar la carga el ordenador me
dice que se ha concluido con exito pero el display de impresora se queda bloqueado con el siguiente texto "ORIGINAL PRUSA I3 PRUSA RESEARCH"  pero si que funciona con la version anterior.
Postato : 29/11/2021 8:47 am
Slayreman
(@slayreman)
RE: firmware 3.10 error
I am having the same exact issue on 1 of my 2 Mk3S+ 's. I even tried loading 3.10.1 RC1. Same problem Stuck on "ORIGINAL PRUSA I3 PRUSA RESEARCH".
Postato : 03/12/2021 11:17 pm
1 persone hanno apprezzato
pw
 pw
(@pw-2)
Looks like I'm having the same exact issue. I updated firmware, it went ok. Then left printer working. Got to it next day and print had completed, but it was showing the "boot screen". Tried to reset and power down, but it didin't help. Going back to 3.9.3 firmware fixed issue for me. Tried to redownload and flash again new 3.10 and my printer immeadiately froze into "boot screen".
Odd..
Postato : 16/12/2021 2:52 pm
pw
 pw
(@pw-2)
Firmware I tried to use was
prusa3d_fw_MK3_3_10_0_4481.hex
SHA-1 Checksum of it was: 0969AFCFE02DAFFB15B3087881C0EB644A78C11A
Postato : 16/12/2021 3:15 pm
Migguel3D
(@migguel3d)
Me pasa exactamente lo mismo, hay alguna solución? Tuve que volver al Firm 3.9.3
Si alguien tiene una respuesta estaría muy agradecido
Saludos
Postato : 18/12/2021 2:47 pm
Make sure you are using the correct version for your printers.  There are both versions for the MK3 and the MK3S and MK3S+.  For example the one pw mentions installing wont work on a MK3S or S+ as its designed for the older original MK3.
Also I notice the latest version is prusa3d_fw_MK3_3_10_1_4697.hex
Postato : 18/12/2021 3:52 pm
Slayreman
(@slayreman)
Hi everyone, just wanted to leave the fix that worked for me. Prusa support suggested:
  • Flash with everything but LCD and power disconnected.
  • Triple check the version of FW
  • Disconnect the power cable from PSU (the external one from power socket) and power cycle the PSU with the button a few times to discharge capacitors
    After disconnecting  all cables except LCD and power , I reflashed with:prusa3d_fw_3_10_1_MK3S.hex and was able to continue as normal.
    My Mk3s+ now works as expected.
Postato : 18/12/2021 6:30 pm
manuel.r6
(@manuel-r6)
Tengo el mismo problema con la version firmware mk3-3-10-1-4697. ¿Alguien sabe como Solucionarlo?
Postato : 01/02/2022 12:45 pm
Migguel3D
(@migguel3d)
Hola, fijate si podés resetear desde el botón que está al lado del conector USB, solo lo tenés que pulsar.- A mi me resultó ese paso, lo reseteé y pude instalar el nuevo firm y quedó funcionando perfecto.-
Espero que se de utilidad.-
Saludos
Postato : 01/02/2022 1:02 pm
manuel.r6
(@manuel-r6)
Hola Migguel
He estado todo el fin de semana intentando instalar el firmware. He probado lo que me aconsejaste pero no
he tenido exito, al final se queda colgado en "ORIGINAL PRUSA I3 PRUSA RESEARCH".y he vuelto a la version 3.9
Gracias por tu respuesta y saludos
Postato : 09/02/2022 7:27 am
Migguel3D
(@migguel3d)
Hola Manuel.r6, que mala suerte!!! Supongo, entonces, que el problema está en el mother (Einsy). Cuando me comuniqué con la gente de Prusa, me comentaron que era un problema de Firmware, y que iban a sacar uno nuevo en poco tiempo, cuando lo sacaron, me hizo lo mismo se me quedaba congelada la impresora.- Lo que opté fue en comprar un mother nuevo (ya que era lo único que podía ser), lo instalé, y cuando lo hice me pasaba lo mismo (se quedaba congelada), entonces tuve que presionar el botón de Reset y recién ahí se pudo instalar el último Firmware y quedó funcionando.-
Lamento no poder de ser de más ayuda pero me parece que no hay otra solución, es una lástima que el soporte de Prusa no nos diga cual es el problema, ya que el mismo radica en la parte electrónica.-
Si lo podés solucionar te agradecería que lo comentaras para tener en cuenta por si me llega a suceder en otra oportunidad. Quedo a tus órdenes para cualquier inquietud.-
Un saludo
Postato : 09/02/2022 11:29 am
manuel.r6
(@manuel-r6)
Hola Migguel.
He estado el fin de semana tratando de buscar una solución a mi problema. Hice una restauración completa del sistema y no tuve éxito. Después desconecté todos los cables de la carta EINSY y actualice el FW a la ultima versión, arranque el equipo y el display presentaba muchos errores al no tener nada conectado pero daba la impresión que funcionaba pues el botón giratorio era operativo. Volví a conectar todo el cableado pero al poner la impresora en marcha el display no salía de la pantalla de inicio. Nuevamente desconecté todo el cableado, (Conectar y desconectar lleva tiempo) y esta vez lo fui conectando por etapas. En la primera el cable PP (blanco y negro) y los termistores de mesa y extrusor metí tensión y funcionaba. Después Ventiladores de extrusor y también funcionaba. Conecte los motores X,Y,Z y E , también funcionaba. Pero al conectar el detector de falta de filamento el software se colgaba. Deje este conector fuera y deje el resto conectado. El equipo funcionaba pero daba el fallo de error en detector de filamento, desmonte la plaquita del detector y estaba algo sucia la zona del espejo y el espadín donde va el cable rojo estaba un poco doblado hacia abajo y no puedo asegurar que hiciera buen contacto. Limpie y enderece el pin lo volví a montar y todo funciona perfectamente. Ahí creo que estaba el fallo.
Saludos
Postato : 22/02/2022 5:44 pm
Migguel3D
(@migguel3d)
Fue todo un trabajo, pero rindió sus frutos. Te felicito!!! Un saludo
Postato : 22/02/2022 6:23 pm
