Filament Runout Firmware issue
Sonar
(@sonar)
Hi
My filament sensor reads 1 when filament present and 0 when it runs out. Thats fine. Sensor working and cabling fine. The mechanical fixing of the sensor and associated hardware must also be ok. However the printer continues to print without pausing with no filament. So I have a failed print. So the problem must be firmware, surely. So I have flashed the latest firmware (3.9.1) and the problem remains. Any help appreciated.
Opublikowany : 01/11/2020 4:49 pm
RE: Filament Runout Firmware issue
Posted by: @brendoncarvill
Hi
Sorry, maybe a superfluous question: Did you activate the filament sensor and did you install the correct firmware (MK3 or MK3S)?
Opublikowany : 01/11/2020 5:00 pm
Sonar
(@sonar)
@karl-herbert
Definately Mk3S firmware and I have toggled the sensor manually and with constant success. Also allowed the filament to deliberately run out whilst monitoring the sensor state on the LCD screen. Everything points to firmware which I accept maybe now is more likely to suggest I have a setting wrong somewhere since this would appear to be a problem that only I am having.
Opublikowany : 01/11/2020 5:17 pm
