Filament run out sensor questions
Forgemonkey
(@forgemonkey)
Hi all,
New to the Prusa's so I apologize if this is a common question. IT would appear that the 3 times I have run out of filament, the sensor does indeed work...but it seems to catch the run out too late...or something like that. When I go to unload the nub (for that is all there is, a mere 1/8 inch of filament poking out of the boden tube, and completely disengaged from the gears of the extruder.
Is there a fix for this or a way to adjust so that the machine stops sooner so I can reload the machine without having to take things apart, and jam a brass rod down the boden to force out enough pla and make space for the new filament to load?
Note I am not getting Jams per se. but If I try and load new filament onto of the 1/8 in nub I just grind filament. Things will not load unless I manually push the remains of the last roll through the hotend, so that I have space to get the new filament into the boden.
Hope this makes sense, and thank you in advance.
-J
Respondido : 09/08/2019 1:42 pm
Dave Avery
(@dave-avery)
RE: Filament run out sensor questions
with or without MMU2 on your machine? IR sensor should stop the extrusion with filament still in the bondtech gears on a plain MK3s. Finda should stop extrusion on a MK3s with MMU2. if you have a MK3s modified for a MMU2 and have the MMU2 disconnected then extrusion will only stop when the filament is past the bondtech gears ( this is what your problem sounds like). the difference is on a MMU2 modified MK3s the IR sensor is sensing the bondtech gear positions and not filament up at the sensor position
Respondido : 09/08/2019 5:49 pm
Forgemonkey
(@forgemonkey)
I have a regular old M3s as far as I know. I did not buy the MMU2. I do know that the machine stops once the filament is about 1/8 above the boden and 100% disengaged from the Bondtech gears.
I'll be happy to put up some pictures once this current print comes off if you think it would help.
Esta publicación ha sido modificada el hace 7 years por Forgemonkey
Respondido : 09/08/2019 6:06 pm
