Filament change fail FW 3.13.2
Reinhard.Poelzleithner
(@reinhard-poelzleithner)
Utenti
after upgrading the firmware to 3.13.2 the manual filament change failed. I wanted to change the spool because it was empty. I paused the print and wanted to change the filament. The unloading was succsessfull, but when i tried to load the new filament, nothing was happening. The extruder stepper and the heating of the hotend was off. I tried several times to select "filament not loaded" but nothing happened. No heating, no movement of the extruder stepper. Maybe I did something wrong, but in the past (with the old firmware) it worked fine.
I worked around by releasing the idler and manualy pushing the filament into the hotend and could resume the print.
Is there maybe some bug in the Firmware, or did I somenthing wrong.
Kind regards
Reinhard
Postato : 24/11/2023 9:18 pm
Nautilus hanno apprezzato
Nautilus
(@nautilus)
Utenti
RE: Filament change fail FW 3.13.2
same here, no unloading afther update....
Postato : 27/11/2023 6:39 pm
PetesActionFigures
(@petesactionfigures)
I have the same issue.  Never had this problem before this version.
Postato : 19/01/2024 10:22 pm
PetesActionFigures
I downgraded to firmware version 3.12.2 and it worked fine again.
Postato : 19/01/2024 11:02 pm
Rob
 Rob
(@rob-16)
Hi there, same problems here on 3.13.2, all prints failed, starting on level 0, after downgrade to 3.12..2 and 1_0_6 all prints are fine.
Imho the firmware is not ready for upgrading MK3s+ and MMU2.
As the prints with 3.12.2 are fine I do not need the upgrade until I upgrade to MK4/MMU3 *scnr*
Postato : 22/01/2024 3:15 pm
