Fan speed at 255
Sunshadow
(@sunshadow)
Fan speed at 255
Hi!
After upgrading to MK3s I have the problem that new fan always jumps to the max speed of 255. This ruins every print because the nozzle gets too cool. I tried to set fan speed settings in the project files, but without success. At the moment I have to reduce the speed manually for the first few layers. But something seems to override the settings and the speed jumps back to 255. After some layers the manual settings don't get overrided. Also tried to update the firmware.
Any idea what to do?
Respondido : 24/07/2021 1:39 pm
xenon
(@xenon)
r
there are settings for the part cooling fan in the filament settings.
the part fan cooling down the hotend sounds...unlikely?
Respondido : 24/07/2021 4:16 pm
Fan speed at 255
Posted by: @sunshadow
Hi!
If you work with PrusaSlicer, you should have a look at the following settings and correct them if necessary:
wbr,
Karl
Respondido : 24/07/2021 4:34 pm
Peter M
(@peter-m)
Check if you did not switch the 2 fans with the rebuild.
Use gcode from prusa to check if it is not your slicer.
Respondido : 24/07/2021 6:46 pm
1 les gusta
Heh. That would certainly explain it!
Posted by: @peter-m
Excellent point! I did this very thing on my Sidewinder.
Respondido : 24/07/2021 8:48 pm
Sunshadow
(@sunshadow)
Maybe...
Hmmm... not sure. How can I identify the correct fan?
Respondido : 24/07/2021 9:43 pm
xenon
(@xenon)
check the assembly pictures.
the hotend cooling fan cannot be controlled manually. it starts automatically if the hotend is hotter than 50°C.
the part fan can be controlled manually from the temperature menu, for example
Respondido : 24/07/2021 9:53 pm
Try printing and adjusting the part cooling fan speed from the front menu
A self-test should identify this, but very quickly: If you're doing a print and you turn the fan speed down from the printer menu and the HOTEND fan (on the side) stops or slows, they're reversed.
Respondido : 24/07/2021 11:11 pm
Sunshadow
(@sunshadow)
Confused
I checked the fans. When I reduce the speed in the printer menu the HOTEND fand slows down. But the wiring to the board is equivalent to the manual....
Respondido : 25/07/2021 7:27 am
Sunshadow
(@sunshadow)
Update!
I was wrong, the Fan setting controls the front print fan, not the hotend. So wiring should be correct.
Respondido : 25/07/2021 7:49 am
Ringarn67
(@ringarn67)
Save, Zip, and upload a project file in which the problem occurs
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Respondido : 25/07/2021 8:07 am
Peter M
(@peter-m)
RE: 1
On prusa website you can download the official stl files, but also the gcode file, these should work, then you can see if it is the slicer.
https://www.prusa3d.com/prusa-i3-printable-parts/
Esta publicación ha sido modificada el hace 5 years por Peter M
Respondido : 25/07/2021 8:14 am
