Extrusion stopping mid-print
Hi all, having major issues with prints stopping mid-print. I have the i3 MK3s.
I am printing PLA, 0.1, using the prusa slicer and it will print fine for a while and then will just stop extruding (print keeps going, no filament).
I have tried
a). pull the hot tip out, clean out the PTFE tube, heat sink, and nozzle
b). replace nozzle
c). Adjusting idler tension
d). Other options here https://help.prusa3d.com/en/article/extrusion-stopped-mid-print_1948
The strange thing is after pulling out and cleaning the hotend, sink, etc... I was able to print the Prusa Vase print just fine, then was able to print another one, then the issue began again.
Seems to be an issue with temperature. I do have the printer inside an enclosure.
Any tips appreciated.
Nick
