Extruder Stepper motor just stops
Dave
 Dave
(@dave-14)
My extruder stepper motor stops after about an hour of printing, if I let it set it will start working again.........
Any ideas?
thanks
drs
Respondido : 29/08/2023 12:58 pm
Check all the connections.  What temperatures are showing on the LCD?
heerio,
Respondido : 29/08/2023 3:38 pm
Dave
 Dave
(@dave-14)
RE: Extruder Stepper motor just stops
Sorry, where do I check the temps?
If you mean on the info screen they are all set to what the slicer is when the gcode is processed.
Respondido : 30/08/2023 2:12 am
And how long is it before it restarts?  Is this repeatable?
Are you using an enclosure?
Respondido : 30/08/2023 5:20 am
Dave
 Dave
(@dave-14)
Hello,
If I let it set for 30 to 40 minutes it will start extruding again.
I have only tried to use the same prints, but yes it is repeatable
No enclosure
thanks
drs
Respondido : 30/08/2023 11:29 am
Hi Dave,
Is the extruder motor particularly hot when it stops extruding?
similarly, is the stepper driver particularly hot, when it stops extruding?
Respondido : 30/08/2023 11:54 am
Dave
 Dave
(@dave-14)
Hello,
it is hot, but not sure if it is too hot......
thanks
drs
Respondido : 31/08/2023 12:12 pm
For magnets to lose their magnetism, they would have to be stinking hot.
did you try the stepper driver?
do you have a hair drier, or other fan that can blow cold? If so, can you direct that towards the controller box?
see if you can cool the controller?
Respondido : 31/08/2023 5:41 pm
Hello
(@hello)
Yeh most likely it's stepper motor driver those motor need to get to 90 degrees c to stop working
Respondido : 31/08/2023 7:08 pm
This will require a little disassembly:  With the extruder gears removed and power off try turning the motor spindle by hand.
You should feel the gentle bumps of the stepper but that's all, if there is any grating or grittiness you may have a failed internal bearing which is seizing with heat expansion.
Respondido : 02/09/2023 7:04 pm
