Extruder Stepper Motor is Dead
alteration
(@alteration)
It doesn't rotate anymore, what can I do?
Opublikowany : 10/10/2019 5:07 pm
RE: Extruder Stepper Motor is Dead
Hi Simone.
first check that the motor plug pins are secure in the plug housing, then make sure the motor plug is is firmly inserted in the socket, and try again
if this doesn't help,
get a test meter and check for continuity
between the first motor wire and the second motor wire,
and
between the third motor wire and the fourth motor wire,
if either circuit is open circuit, you probably have a broken wire
if this is the case, the break will probably be behind the extruder cable strain relief mounting point
cheap option... if you can identify which wire is broken, replace the wire... insulate repair!
my choice option, replace all four wires with flexible silicone insulated wire, insulated with heatshrink tubing from the fixed part of the extruder cable strain relief mounting into the einsy box...
expensive option replace whole motor with prusa extruder motor,
alternative option, replace with LDO cool running equivalent motor...
more complex options
consider 0.9degree motor and revise firmware,
consider bondtech, or bunny science, or skelestruder upgrades with pancake motor and revised firmware...
other options do exist, but there should be enough here to get you going
if the motor continuity is good, try swapping the X or Y motor plug, onto the extruder socket, on the einsy board, and using the settings >move axis, e axis option, see if the e motor driver will drive the X or Y motor...   if it does not drive the other motor the  einsy may be faulty
https://www.ebay.co.uk/itm/Silicone-Cable-Flexible-Wire-8-10-12-14-16-18-20-22-24-26-30-AWG-Various-Colours/361296232202?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Da3b481dd61b24866b25cc02b2ea6b21f%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dpp%26sd%3D361296232202%26itm%3D361296232202%26pmt%3D1%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3Aa41a54c2-eba9-11e9-959d-74dbd180715d%7Cparentrq%3Ab7b1c7cb16d0aada623df2f0ffeaca62%7Ciid%3A1
24 gauge wire will be adequate
Opublikowany : 10/10/2019 10:01 pm
1 ludzie polubili
alteration
(@alteration)
Thanks for response, I tried the first suggestion and now the stepper motor rotates again. However, I can hear a clog (like a click) when the filament goes down, and the extrusion is weird. What can I do?
This post was modified 7 years temu 2 times by alteration
Opublikowany : 10/10/2019 11:02 pm
could there have been 2 wires faulty?
can you show a video?
Joan
Opublikowany : 11/10/2019 12:23 am
alteration
(@alteration)
I don't think it's wires fault. You can note the gears of the extruder blocked when the click happens.
Opublikowany : 13/10/2019 3:44 pm
alteration
(@alteration)
Sorry, time to edit is expired, so I write down there other informations:
You can note that the gears of the extruder are blocked when the click happens, probably that is the source of the noise. I think it's like the filament encounters some sort of resistence going down, but that's unlikely, because I replaced the nozzle and that still happens. Also the filament is extruded well until the click, then it assumes an irregular form. I think, but it's only an assumption, the stepper motor doesn't have the "strenght" to push the filament down. It doesn't block if there is no filament to push down.
Opublikowany : 13/10/2019 3:54 pm
alteration
(@alteration)
Up, also another question: My 3d printer should still be under warranty, does it cover this kind of damage?
Opublikowany : 14/10/2019 12:54 pm
rmm200
(@rmm200)
Posted by: @simone-b3
Not a question for here.
Go to EShop, log in, and press Chat in the lower right.
They will step you through it.
Opublikowany : 14/10/2019 3:42 pm
airsyspro
(@airsyspro)
My extruder motor stopped working during a print, I found this thread and started trouble shooting the problem. I removed the plug housing cover and tried to remove the extruder plug, Since I bought the printer assembled I have no idea how to remove it as I tried to pull on it and it did not budge. Is there a clip that I have to press on either the plug or the receptacle to remove it?  If it is the cord is there a specific one I should order. I notice several different ones on Amazon. Same goes for the Extruder motor, is there also a specific one I should order if need be?
Thanks Larry
Opublikowany : 20/09/2020 2:19 pm
airsyspro
(@airsyspro)
Update, I was able to remove the extruder wire plug from the circuit board there is a tab that locked in. However, I cannot figure out how to remove the wire plug from the extruder.
Opublikowany : 20/09/2020 4:15 pm
airsyspro
(@airsyspro)
Update, I was able to remove the extruder wire plug from the circuit board there is a tab that locked it in. However, I cannot figure out how to remove the wire plug from the extruder. I took Joan's advice and plugged the extruder into the Y axis plug adapter. I tried to move the extruder motor using the Y movement in settings and nothing happened. Have to assume it is the wiring or the motor. Is there another source in the United States where I can get a new stepper motor with wiring??
Opublikowany : 20/09/2020 7:07 pm
I believe Printed Solid should be able to help.
Opublikowany : 20/09/2020 10:45 pm
airsyspro
(@airsyspro)
Thank you Joan, I have contacted them.
Opublikowany : 21/09/2020 1:57 am
Kraut55
(@kraut55)
I also have an extruder motor problem. (Initially it was a PTFE tube problem but after disassembly of the E assembly and re-assembly the extruder motor decided to stop working).
I followed Joan's advice and
- checked continuity, both 1/2 and 3/4 are ok (motor ok?)
- switched the X cable to the E plug, x-axis is moving when I increase/decrease the value of E, so the plug is ok.
What else could I try?
Thanks
Hans
Opublikowany : 22/03/2021 6:33 pm
Kraut55
(@kraut55)
In case somebody should run into a similar problem:
I had a chat with Prusa support. The last suggestion (Thank you, Jakub) was: "Did you try removing the motor from the extruder completely to make sure it is not stuck? It is possible that the bondtech pulley is stuck somewhere and it causes the motor not to be able to turn".
That solved my problem and saved me more than 40€
Opublikowany : 24/03/2021 6:58 pm
As @joantabb indicated, Printed Solid has Prusa compatible parts.
I contacted Printed Solid and Filastruder.  Both have motors from LDO that will work.  Pick the one closest.  Filastruder and Printed Solid usually get them to me in 2-5 days.
Opublikowany : 25/03/2021 12:51 am
