Extruder skips due to squeaky idler bearing
Recently my MK3S+ developed the problem of occasional extruder skips. At first I thought it was the result of me replacing some hot-end parts, or a clogged nozzle. But it turned out to be dry bearings in the extruder idler. It made squeaky sounds, but I wasn't expecting it to have the skipping effect. Lubricating the bearings fixed both the squeaking and the skipping.
Greetings,
Fred Jan
Opublikowany : 28/09/2022 10:05 am
RE: Extruder skips due to squeaky idler bearing
Which bearing did you replace?
Opublikowany : 29/09/2022 10:40 am
Topic starter
answered:
Hi Chuck,
These were the bearings on the extruder-idler* shaft. I didn't replace them, as lubricating (tiny bit of oil) fixed both the squeeking and the filament skips.
Fred Jan
*) https://help.prusa3d.com/guide/5-e-axis-assembly_169235, Step 32 Extruder-idler parts preparation
Opublikowany : 29/09/2022 11:48 am
