Extruder motor stops rotating during print
Ivo Dyntar
(@ivo-dyntar)
During printing, it happens to me that the extruder motor stops completely rotating in the random layer. There is no click as in the clog, there is no grooved groove on the filament, it just dies. After stopping printing and entering the menu with the possibility of moving the motors, nothing happens when trying to move the motor of the extruder, the motor still refuses to rotate. If I turn the printer off and on, the motor can be operated manually, and it works for a while after printing starts, but then the situation repeats, stopping spinning again. The nozzle is clean, pierced with a needle and a coldpull was performed. This problem manifests itself in various gcods. No screws are allowed, the engine is not extremely hot to the touch.
Opublikowany : 11/05/2021 9:10 am
RE: Extruder motor stops rotating during print
Have you contacted support via chat?
Opublikowany : 11/05/2021 10:09 am
Stewart
(@stewart)
This is currently happening on one of my printers right now, was there a fix for this issue?
Opublikowany : 29/07/2022 6:33 am
