Extremely hot motor
Tectonico3D
(@tectonico3d)
Extremely hot motor
Hello guys I have a summer problem here. I have my machines since winter and now we are in summer and it's really hot here. I never had problems with the gears skipping on the filament. But I also never did print in summer before or tried to print PETG. Well my motor it's getting so hot that I can barely touch it for a few seconds. Last week I couldn't even print PLA and the prusa chat recommended to add thermal paste inside the extruder. And that fixed the issue but only with PLA. Now that I am working with PETG with higher temperature after 1 hour of printing I start getting the motor so hot and the gears don't grab real well filament. I had a problem like that before also with PET. At 270 degrees Celsius. Now I am printing at 255 degrees Celsius and I still have problems. Any advice on how to fix this issue? I have read that adding a fan on top of the motor will help to cool down the motor but will that help with the skipping problem? I have the tension screw just right and even if I slow down the printing speed I get the skipping. Thanks for the help.
Respondido : 14/01/2020 3:40 am
padigree
(@padigree)
RE: Extremely hot motor
If the motors get that hot, I don't wanna know how your TMC2209 drivers will feel in their sauna..
I dont understand why they don't add a simple blower or some good heatsinks to the board.
Skipping is more often caused by too hot motor drivers. Sure, if your stepper itself is glowing, this could also be a cause.
Printing on hot summer days could also be as hard as on cold winter days with extremely low ambient temperature.
Give it a try (you dont have to install a fan properly, simply use something that blows the heat "a bit away" and watch if there is
any improvement.
Kind regards
It’s better to give than to receive. Especially advice.
Respondido : 14/01/2020 5:54 am
Crawlerin
(@crawlerin)
Wait, MINI was not out half a year ago... how did you get it? Were you some super-early-pre-alpha tester? 😮
Either way, if you have MK3, people had some success with sticking aluminum heatsinks to motor which helps dissipate heat a bit. Airflow helps too but don't blow on print area, prints will warp.
Respondido : 14/01/2020 1:52 pm
1 les gusta
Nikolai
(@nikolai)
Let us know your ambient temperatures. Hot motor on the MK3 ( I assume you have MK3 and not Mini ) is nothing unusual.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 14/01/2020 6:29 pm
I regulated my extrudertemp. problems (over 60 degree) with a simple 40x40 noctua fan and a printed housing. The temperatures dropped to 35 degrees.
additional weight: approx. 20 grams. Air blows to the Extruder gears and not to the printbed. I used an external Meanwell 12V Powerunit.
Respondido : 14/01/2020 8:32 pm
1 les gusta
Tectonico3D
(@tectonico3d)
@padigree
Thanks for the reply. I already try a house fan that I place near the printer blowing from bottom to top. it did not help at all in the problem. but it did reduce the temperature of the motor a bit.
Respondido : 14/01/2020 8:37 pm
Tectonico3D
(@tectonico3d)
@crawlerin
oh my god I am sorry I did not realized that this was the mini forum section. I saw the problem I was reading and I decided to post and I did not look correctly. I have the MK3S
Respondido : 14/01/2020 8:38 pm
Tectonico3D
(@tectonico3d)
@nikolai-r
I have the MK3S and today for example temperature here in my city its 32 degrees celcius. inside my room it gets easily at 35. I dont have a thermoter. I am waiting to arrive here in the mail soon.
Respondido : 14/01/2020 8:40 pm
Crawlerin
(@crawlerin)
Posted by: @ciscolara
@crawlerin
Lol that's ok, we figured 😀 But you never know, you could have been tester of some early unit who faces problem with hot motor now, but I guess in tgat case you are close enough to Prusa Research that you wouldn't need to go to public forums. Now, of all the initial complaints about MINI I haven't seen hot extruder motor yet.
If it causes issues with extrusion, you may be facing heat creep from hot motor to gears and in that case cooling motor may be a good idea.
Respondido : 15/01/2020 1:44 am
Zoltan
(@zoltan-d-2)
Miembro Moderator
Moving to the correct thread, probably more people will join.
Respondido : 15/01/2020 7:43 am
1 les gusta
