EXport and import configurations
3Dfiguras
(@3dfiguras)
Hello,
two week ago i bought a 0.2 nozzle to be used in my  prusa mk3s the problem is that if a change the nottle size in prusa slider, it generate a new printer and all filaments and quality configuration paramters are empty, with this new printer, i i change the  configuration to the 0.4 nozzle , the filament and quality configuration  return to be selected.
Please do you know or exist any  method to export import, configurations between printers into the prusa slicer?
I know tha in the file options there is a option to export and import but it is only between programs o to save the currently configuration but it is not import into the new printer.
thank yo very much in advance
Postato : 02/09/2022 9:57 pm
Utenti
RE: EXport and import configurations
I do not think this is possible.  I think you have to add them to PrusaSlicer as an STL file or similar file and reslice the GCODE.
Postato : 10/09/2022 12:15 pm
You might want to thoroughly read all the info available on Bob's site https://projects.ttlexceeded.com/3dprinting_prusaslicer.html   as I foresee you will be doing some profile editing in your future.
Postato : 10/09/2022 3:24 pm
