Explain la for me please
Alucardi
(@alucardi)
I do not get how this stuff work. Do I need to activate it with a special g-code for all my profiles? Or can I just print and it’s there?
Do I need to calibrate it depending on filament? I print mainly just tpu.
I have a mk3s running latest firmware (not alpha or beta).
Respondido : 17/01/2020 11:00 am
Alucardi
(@alucardi)
RE: Explain la for me please
Since there is no edit button atleast not when using a iPhone I give some more Info here. I use pretty profiles but not for tpu. I saw that prusa is getting la 1.5 so I guess if I am to calibrate tpu I need to use a new system or does it work the same? Do I need to calibrate for each type of filament brand or is it enough to do pla, petg and so on?
Respondido : 17/01/2020 11:39 am
Chris Warkocki wrote the 'Pretty' profiles, he may be your best point of contact!
or have a look at your G code
one of mine has:-
M900 K18 ; Filament gcode  (Linear Advance) setting in prusa profile for PLA
the Prusa Generic flex, and Semiflex or flexfil 98a both have M900 K0 ; Filament gcode   (Linear advance turned off)
your profile may be different...
In Prusa Slicer the linear advance setting is done in the 'Filament Settings>Custom Gcode' menu which is an 'Expert Mode' Option
for TPU, I turn retraction off too!
and for small sections I turn the fan on and reduce speed!
Regards  Joan
Respondido : 17/01/2020 3:33 pm
