"ERROR: PREHEAT THE NOZZLE!"
carolyn.l2
(@carolyn-l2)
Lately I'm getting this error, and then I can't leave the error message to go and preheat the nozzle. This only happens sometimes. Suggestions?
Edit: Now it's happening all the time. Printer is unusable.
Veröffentlicht : 07/05/2018 1:10 am
carolyn.l2
(@carolyn-l2)
Re: "ERROR: PREHEAT THE NOZZLE!"
Once the printer gets to this error message, it freezes up and I can't go back to the main menu. Is this a firmware issue? Busted thermistor?
Veröffentlicht : 07/05/2018 1:23 am
Erik
 Erik
(@erik-3)
It sounds like your filament sensor is wigging out. Try cleaning it. Remove the little plug on the top of the extruder carriage and blow some compressed air in there. Just a quick spritz should do it. The error will go away after a few seconds that it doesn't detect "filament" in the bondtech gear housing. If you keep having this problem you should disabled the filament sensor while you look for a fix.
Veröffentlicht : 07/05/2018 3:38 pm
carolyn.l2
(@carolyn-l2)
I tried letting it sit and presumably heat up. Getting mixed results. WIll try your suggestion. Thanks.
Veröffentlicht : 08/05/2018 3:56 am
