Error MAXTEMP when printing PCCF
FX
 FX
(@fx)
Hello Community,
i recently received my preassembled & tested I3 Mk3s+ along with some PCCF Material which i mainly want to use. I changed the nozzle for an Olsson Ruby and started printing with the preset settings from Prusa Slicer for PCCF @ 285°. Print was smooth until the last few layers where the Printer showed the MAXTEMP error along with the siren.
I thought maybe the AC caused it, printed again - no issues, print went through. Today, i started printing again, MAXTEMP error twice after 2 layers of a very small print.
I checked around, no creasing, noticable defects around the Thermistor. Also during printing, the Temperature monitoring on the screen doesnt spike or go off, it stays within a reasonable measurement.
I unplugged it while room temp, measured with a multimeter and the resistance was normal, i also moved the cable around during measuring and no changes.
Now im printing PLA @ 220° and no errors.
What could cause this? i know the MAXTEMP error ocurrs when the thermistor exceeds 305° but that did not display, or rather the temp didnt really go over 288°.
Could AC in a room really cause the thermistor or rather the PID heating to malfunction and produce MAXTEMP errors constantly? i dont know what else to try.
Thanks in advance.
cheers felix
Opublikowany : 28/07/2022 1:01 pm
RE: Error MAXTEMP when printing PCCF
Hi Felix,
Maxtemp can be caused by a thermistor shortcircuit... check where the wires come out of the Heater bulb
Opublikowany : 28/07/2022 6:00 pm
FX
 FX
(@fx)
Hi Joan, yes i did check along the wire coming from the hotend, i dont see any damage or anything out of the ordinary, also when i was measuring resistance at the molex connector at room temp i wiggled the cable, moved the head and generally tried to move the cable and connection around - no change in resistance or shorts.
I also managed a full 3h print with PLA@220° with no errors, meaning if the thermistor would short sometimes during head movement if should short regardless of temp right?
I dont really understand why the MAXTEMP gets triggered when printing at 285° - thats my issue
This post was modified 4 years temu by FX
Opublikowany : 29/07/2022 11:39 am
285 is near the top of the range,
You could try doing a PID tune at that temperature to reduce the chnces of the heater cycling too high and causing a genuine maxtemp indication.
Opublikowany : 29/07/2022 8:27 pm
Niggurath
(@niggurath)
Have exactly the same issue. Do you find the problem? Kind regards
Opublikowany : 04/08/2022 6:20 am
FX
 FX
(@fx)
Hey all,
i was out the past week and couldnt test it yet. I will try a PID tune at 285 but i did one before @220 and am not very hopeful that this is the issue.
I also might try printing at 270° instead of 285° if it still works and leave some findings if i learn anything else. Is there any way to tell the printer to be "less" sensitive to temp spikes when printing @285°? I know it would mean custom firmware but i think just printing 20° below max should not cause such issues - especially since the thermistor clearly works and would alert when overheating anyways.
Basically increasing max temp limit by 10° could solve it or include a timer for how long over temp has to occur to cause maxtemp.
Thanks still,
Feilx
Opublikowany : 08/08/2022 11:37 am
FX
 FX
(@fx)
Update:
Today i got a full print down, 33 minutes @ 275°C all good. Ran a PID cal. at 280 before.
Ill see if the MAXTEMP occurs again.
Thanks so far,
Felix
Opublikowany : 11/08/2022 3:04 pm
Niggurath
(@niggurath)
Hi Felix! As mentioned, I had the same issue. Had two days with the support team testing everything possible. Without success. At the end I will get a new board.
To print under the standard for this material is not the solution. I would highly recomment you to push to a board exchange.
On my other MK3 I already printed more than 15kg PCCF at standard settings without an issue
Kind regards
Opublikowany : 11/08/2022 3:11 pm
FX
 FX
(@fx)
Thanks for the answer - in this case its pretty obvious since you ran through a lot of material beforehand!
Youre right, its just a fix and not the solution - doesnt make sense to me that the thermistor works normally, no faults or shorts and still prints produce errors.
Could you maybe send me the Support Ticket number so i can send a mail to support? Just so i can reference this in case.
Thanks,
Felix
Opublikowany : 11/08/2022 3:46 pm
linenoise
(@linenoise)
I'm experiencing a similar problem.   I've tried 5 times to print the same model in PCCF and it fails in a similar area.   The last time I watched the temp instantly spike from 270 (I had lowered the temp) to 329 and trigger a max temp situation.   Instantly.   I have tried the PID calibration, printing at lower temps than 285, etc.    No luck.
Its really strange that all the prints are failing in a similar spot?
I'm now trying the same model print with PLA.   I suspect it will be successful.    I have a new thermister on order in case that is the cause.
Did anyone above make further progress on this issue?
Colin
Opublikowany : 03/12/2022 9:24 pm
Niggurath
(@niggurath)
The answer is quite simple. It's the same spot because the is an overhang to print. The part cooling fan turns on and this leads into this error. solution: silicon sock.
Opublikowany : 03/12/2022 11:32 pm
linenoise
(@linenoise)
I ended up upgrading my firmware from 3.11.0 to the latest beta / release candidate 3.12 RC1 and the problem went away.   I'll check out a silicon sock as well.
Opublikowany : 04/12/2022 5:10 am
