Error M112
Eric F.
(@eric-f)
Error M112
Hello,
Today I got this error when tying to print
Send: N600 G1 X143.938 Y79.144 E0.02211*95
Recv: ok
Send: N601 G1 X144.577 Y79.443 E0.02211*92
Recv: ok
Send: N602 M105*35
Recv: ok T:215.0 /215.0 B:57.7 /60.0 T0:215.0 /215.0 @:30 B@:127 P:40.0 A:38.7
Send: N603 G1 X145.156 Y79.848 E0.02215*91
Recv: ok
Send: N604 G1 X145.654 Y80.346 E0.02212*93
Recv: ok
Send: N605 G1 X146.059 Y80.925 E0.02215*92
Recv: ok
Send: N606 G1 X146.358 Y81.564 E0.02211*81
Recv: ok
Send: N607 G1 X146.540 Y82.245 E0.02211*88
Recv: Error:Temperature heated bed switched off. MINTEMP triggered !
Recv: // action:cancel
Changing monitoring state from "Printing" to "Error: Temperature heated bed switched off. MINTEMP triggered ! - // action:cancel"
Send: M112
Send: N608 M112*47
Send: N609 M104 T0 S0*46
Send: N610 M140 S0*98
Changing monitoring state from "Error: Temperature heated bed switched off. MINTEMP triggered ! - // action:cancel" to "Offline (Error: Temperature heated bed switched off. MINTEMP triggered ! - // action:cancel)"
Connection closed, closing down monitor
I upgraded to the latest firmware, but I got the same issue again.
I tried to do an"heatbed calibration", it failed with "Issue Err MINTEMP BED"
Any idea what first step I should do =?
Napsal : 11/01/2021 5:06 pm
RE: Error M112
Posted by: @eric-f-2
Hello,
Recv: ok
Recv: ok
Send: N602 M105*35
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Send: M112
Send: N608 M112*47
Are you printing in a cold environment or is there draught somewhere?
https://help.prusa3d.com/en/article/mintemp-and-mintemp-bed_2169
Napsal : 11/01/2021 5:57 pm
Eric F.
(@eric-f)
RE: Error M112
I am printing in my company office, it is around 21-22 degree Celsius.
/Eric
Napsal : 11/01/2021 6:21 pm
Eric F.
(@eric-f)
RE: Error M112
Thanks,
The issue is with the thermistor, I will try to change the cable.
/Eric
Napsal : 12/01/2021 5:49 am
yvr76
(@yvr76)
RE: Error M112
I've been running into this as well, but only via OctoPrint (logs below).  If I use the printer to preheat first then the bed warms up promptly and then I can start the print via OctoPrint without issues.  So this leads me to believe it's not a hardware issue, but firmware or software?
MK3S, Firmware 3.9.3, PrusaSlicer 2.3.0, OctoPrint 1.5.2
Recv: T:215.21 E:0 B:30.7
Cancelling on request of the printer...
Changing monitoring state from "Printing" to "Cancelling"
Recv: Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Changing monitoring state from "Cancelling" to "Error: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)"
Send: M112
This post was modified před 5 years 2 times by yvr76
Napsal : 12/01/2021 8:15 pm
notdoingit
(@notdoingit)
RE: Error M112
@yvr76
An intermittent open in the bed temp sensor wire can cause what you describe.  I found my cable fault right at the plastic hood at the point where the cable attaches to the bed.  This makes perfect sense because it would be a stress point as the bed moves back and forth.
I made this to show how to verify I found the problem.  Intermittent opens and shorts can be a real pain to find.  You can draw incorrect conclusions even using a multimeter or a TDR.  This method, while a bit risky, does let you verify beyond all doubt that you found the problem.
So it's clear that I did in fact cut out the bad section.  Now we just apply some solder and heat-shrink tube and we're back to printing!
Napsal : 12/04/2021 2:20 pm
