einsy rambo board replacement procedure?
kevin.g13
(@kevin-g13)
Greetings.
I own a I3 Mk3 (upgrade to S) {out of warranty} and have been told my einsy rambo board is bad.  I was wondering if anyone can answer two questions for me: (1) which board to get for a replacement; the Einsy Rambo 1.1A or the Einsy Rambo 1.1B and (2) is there a written procedure on what to do to install a new out of the box board.  I ask as I can't find anything and would hate to just 'plug it in' as I would do for a firmware update and fry a new board by accident.
Thank you in advance and stay safe out there.
Opublikowany : 01/04/2020 12:40 am
K7ZPJ
(@k7zpj)
RE: einsy rambo board replacement procedure?
If you order one from UltiMachine and tell them to setup it up for the Orginal Prusa i3 MK3S in the order notes  you will get the right board / options.   einsy-rambo
The documentation for the Einsy-Rambo:  EinsyRambo Docs
However, the easiest way to do it is,  just order one from Prusa.
Opublikowany : 01/04/2020 1:14 am
