Earthing problem since firmware 3.12.2 on MK3s
Ever since I "upgraded" the firmware to 3.12.2 on my MK3S if I touch any metal part while it is printing it acts as if there was a power failure and restarts. I had to disable the thermal test otherwise I could not print anything and now this. Should I backtrack the firmware to the previous version?
Opublikowany : 02/06/2023 8:13 pm
RE: Earthing problem since firmware 3.12.2 on MK3s
Earthing is no firmware feature. You should check the conductivity of your PE and the insulation of the other cables.
Opublikowany : 03/06/2023 8:45 pm
