E3D V6 0.15 Nozzle, HELP!
Fabrikk
(@fabrikk)
Hi everybody,
I started practicing with this experimental nozzle for tiny ans high detailed prints but after a good start I messed up something.
At first I printed using standard 0.25mm nozzle settings from Prusa Slicer database
results were decent but not far from that better compared to those obtained with 0.25mm nozzle
I have tried using 0.25mm nozzles settings but changed extrusion width to 0.18mm   ====> seemed nothing changed.
So I started to change some parameters according to E3D guide for 0.15 nozzle and things went worst,
Opublikowany : 04/08/2022 7:54 am
Fabrikk
(@fabrikk)
RE: E3D V6 0.15 Nozzle, HELP!
Here Below you can read the suggested settings, I had some difficulties in finding some settings in Prusa Slicer (may be u can help me matching point by point ?)
EXTRUDER
Nozzle Diameter 0.15 mm
Extrusion Multiplier 1
Extrusion Width 0.18 mm
Layer Height 0.08 mm
Retraction Distance 1.00 mm
Extra Retraction Distance 0.00 mm
Retraction Vertical Lift 0.00 mm
Retraction Speed 30.0 mm/s
Coasting NO
Wiping NO
LAYERS
3 layers top, bottom and sides printed inside out
First Layer Height 160%
First Layer Width 120%
First Layer Speed 50%
INFILL
type Triangular (0, 60, -60)
Interior Fill Percentage 25%
Outline Overlap 15%
Infill Extrusion Width 100%
Minimum Infill Length 5.00 mm
Print sparse infill every layer
SUPPORTS
Support Infill Percentage 30%
No extra inflation distance
No dense support layers
Support every layer
Horizontal Offset From Part 0.30 mm
Upper Vertical Separation 1 layer
Lower Vertical Separation 1 layer
Max Overhang 45°
SPEEDS
Default Printing Speed 30.0 mm/s
Outline Underspeed 75%
Solid Infill Underspeed 80%
Support Structure Underspeed 80%
X/Y Axis Speed 80 mm/s
Z Axis Speed 16.7 mm/s
Opublikowany : 04/08/2022 7:59 am
Fabrikk
(@fabrikk)
So about now the best setup was using 0.25 mm settings with just 0.15mm extrusion width.
Can you share your settings with 0.15 nozzle?
Otherwise could you point me in the right directions telling me which parameter I can try to change to see if printing quality and details improve?
Thanks a lot
Opublikowany : 04/08/2022 8:01 am
