Dissolving glue between PEI foil and steel
kolin
(@kolin)
Hi.
I have destroyed one side of smooth PEI plate so I peeled it off. Used glue stinks real nasty and leaves a lot of residue on steel. I have tried following solvents to remove it without luck:
  • Perchlorethylen
  • Ethanol
  • Toluen
  • Benzin
  • Chloroform
  • Acetone
  • Methylethylketone
  • Dichlormethane
  • S6001 paint thiner
  • S6005 paint thiner
  • S6300 paint thiner
Methylethylketone had slight effect. Paint thinner S6001 had better effect. But still nowhere near enough to wipe the remains off.
I have not yet tried to submerse whole sheet in solvent and let it work overnight. The other side can still be usable. If glue won't come off I will peal off the other side and then put it inside the solvent.
Does anyone know what glue is there? I have never seen stuff like this...
Postato : 20/04/2020 8:04 pm
Mike Daneman
(@mike-daneman)
RE: Dissolving glue between PEI foil and steel
I believe you need limonene to dissolve that glue. Here are instructions from Prusa:
https://help.prusa3d.com/en/guide/replacing-the-pei-sheet-on-the-mk3s-mk3-mk2-5s-mk2-5_23920
Postato : 21/04/2020 4:08 pm
DJ
 DJ
(@dj-6)
IIRC the glue doesn’t dissolve so much as it just gets soft enough to scrape off.
DJ
Postato : 22/04/2020 2:40 pm
Olef
 Olef
(@olef)
Limonene works. Not a job for the faint hearted or those affected by very strong smells (orange actually)
Postato : 24/04/2020 10:42 pm
