Different Filament starting Z heights gcode
devilhunter
(@devilhunter)
Anybody know of a good way to set specific starting z heights per printer starting gcode and filament gcode?
Lets say i have a general Z offset of -0.800, for PLA
PETG likes to be printed +0.150 higher, or else it will fuse with the bed.
Black ABS likes to printed at -0.850, and my white ABS at -0.950 (almost into the bed)
I cannot watch the live Z height all the time, and when switching from white ABS to PETG and forgetting to set the z height, a catastrophe will happen.
If i set a +absolute +0.150 in the PETG filament gcode section, the starting gcode of the printer will print it's intro line at -0.800 regardless, then the filament gcode takes over and the normal print will be +0.150 higher.
Low starting intro line still damages the bed though.
Opublikowany : 07/06/2018 1:07 pm
stahlfabrik
(@stahlfabrik)
Re: Different Filament starting Z heights gcode
I also wonder for a long time if there is a gcode to set the live adjust Z value. Are you aware of any? Or is that your question, too - just in other words?:-)
Best regards!
Opublikowany : 07/06/2018 1:30 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Well, you can always try KISSlicer which allows you to have filament-specific user-defined G-code which can be inserted into the printer G-code sections.
I think that you would need to set the initial absolute Z height, then reset the Z value (G92).
Peter
Opublikowany : 07/06/2018 2:10 pm
Dibujor
(@dibujor)
I'm surely saying something stupid here because of lack of knowledge but, can't you use the z-offset in the printer settings for that? Although the description says it applies that offset to all the z coordinates in the g-code you you would still have the problem with the purge line I guess
Opublikowany : 07/06/2018 4:36 pm
Tiago
(@tiago)
Peter
Slic3r have it too, under "filament -> Custom G-Code"
Also you can do general IF under printer gcode. eg: M221 S{if layer_height<0.075}100{else}95{endif} Thats for flow, but will work with filament_type too, still use filament gcode would be better to avoid if mess
Not possible right now without hack the gcode via manual or octoprint plugin but prusa could implement a g-code for set live z, that would be cool and easy
Opublikowany : 07/06/2018 4:42 pm
Martin Wolfe
(@martin-wolfe)
I just create a new printer settings entry in Slic3r. On the "General" section in "Sizes and coordinates" there is an entry for Z offset. As the PETG I use prints slower than the default given setting I just switch "Print Settings", "Filament Settings" and "Printer Settings" over to the PETG entries I created.
No need to mess around with G-Code that way.
Regards,
Martin
Martin Wolfe
Opublikowany : 08/06/2018 5:39 am
mdpauley
(@mdpauley)
Wouldn't M851 help? http://marlinfw.org/docs/gcode/M851.html
Opublikowany : 30/10/2018 8:12 pm
The Plastic Shed
(@the-plastic-shed)
Why bother ?
If you set up a printer profile in Slic3r PE you can play with the Z offset in there, have a profile for each material with the Z offset plus or minus whatever and nothing special is needed in the gcode.
It's as easy to edit the z offset on the printer tab as it is to mess about adding / removing lines of gcode so I'm with Martin.w15 on this one.
Opublikowany : 30/10/2018 9:52 pm
rodrigo.a2
(@rodrigo-a2)
Adding a custom z-offset in the "Filament Settings/Custom G-Code/Start G-code" field will set Different Filament starting Z heights for you, depending on your filament profile.
There is a description of how to do it at https://3dprinting.stackexchange.com/questions/5931/adding-extra-z-offset-to-bed-for-petg-in-slic3r/5932 , which says to move the desired offset in the z-axis and then reset the z value to zero, but that didn't work for me because the Marlin firmware (empirically observed, not confirmed in code) did not let me set z lower that 0 mm. Instead, this is what is working for me :
; Custom z-offset for PLA to improve bed adherence
G92 Z0.1 ; Redefine the zero Z level at the oppostite of the target offset
G1 Z0 F500 ; Go to the new z=0 level of the printer.
I had to implement this feature because switching between PETG and PLA resulted in very different bed adhesion. PLA prints would lift if I used the z-offset for PETG, so I had to lower it by about 0.1 mm. On one occasion I forgot to raise z-adjustment back and the PETG stuck to my PEI bedplate so strongly that I ended up ruining the bedplate when removing the piece's support.
Opublikowany : 07/03/2019 8:21 pm
You could change the print settings and save a print profile for each type of filament.
Set layer one to a different height for each?
Opublikowany : 07/03/2019 8:46 pm
Robin
(@robin-4)
Just set up a printer profile in printer settings. Alter the Z offset:. Any values entered here are either added or subtracted from the live Z height that was done. So if you want the nozzle closer to the bed then insert a negative value i.e. -0.1mm will take the nozzle 0.1mm closer to the bed.
I have one set for +1.35mm so i can print on to a textured HIPS sheet surface on top of the print plate.
Opublikowany : 08/03/2019 1:31 am
Pedja
(@pedja)
RE: Different Filament starting Z heights gcode
Posted by: @devilhunter
This is how it works for me: I set First layer Z height for PLA, and then create printer profile for PETG where I set Z-offset to raise Z a bit. Effect seems to be the same as I changed First layer Z height.
Opublikowany : 08/08/2020 6:54 pm
