[Gelöst] Did I kill my headbed?
Q
 Q
(@q)
Hi all,
New to 3D printing and Prusa. After a few print, I started to have various issues and decided to go through a full calibration. During Z axis, I reacted too late to the "take the paper" error and got my nozzle making a nice mark in my headbed. Did I essentially kill it and need to replace it?
Thanks for your insights!
- Quentin
Veröffentlicht : 29/07/2021 12:19 am
jsw
 jsw
(@jsw)
Does it heat properly?
Do you have something like an infrared digital thermometer that can tell you if it is or is not heating evenly across the build plate?
Veröffentlicht : 29/07/2021 12:31 am
Mitglied
heated
It should still be ok.
Posted by: @q
Hi all,
- Quentin
Veröffentlicht : 29/07/2021 12:40 am
Q
 Q
(@q)
thanks!
@jsw I don't have such a thermometer (yet). But it's good to hear that this is the expected failure.
@cwbullet - that's a relief - thanks!
Veröffentlicht : 29/07/2021 12:48 am
Mitglied
Issues
No big deal.  Keep us updated is there are an issues.  I have one with far more damage.  I call it ole rusty.
Veröffentlicht : 29/07/2021 9:45 am
RE: Did I kill my headbed?
Posted by: @q
Hi all,
- Quentin
As long as no copper lines come to light, the bed should be ok. You can tape over the damaged area with a very thin (0.01-0.02mm) small peace of Kapton (Polyimid) film.
wbr,
Karl
Veröffentlicht : 29/07/2021 10:54 am
Baklin
(@baklin)
title
And I would re check/adjust the PINDA sensor.
I thinks yours is a little high causing the nozzle to hit the bed. Mine runs the calibration fine without the sheet of paper and never touched the bed.
https://help.prusa3d.com/en/guide/9-preflight-check_176167#176175
Veröffentlicht : 29/07/2021 5:25 pm
Q
 Q
(@q)
@karl-herbert that's good tip, thanks a bunch!
@baklin indeed, moving the PINA around fixed the bed hitting. This is probably one of the most delicate piece to adjust (I had a lot of back & forth prior to finding the right level).
Veröffentlicht : 29/07/2021 5:36 pm
jsw
 jsw
(@jsw)
A while back there was a report (here? might have been elsewhere) where someone was able to very carefully scrape/sand/whatever down to the bare copper on the heat plate and very carefully repair a break with silver solder.  IIRC, the 'heater' is actually like a copper foil print on a PC board.
Veröffentlicht : 29/07/2021 7:40 pm
Mitglied
copper
That does not look deep enough to hi the copper.
Veröffentlicht : 29/07/2021 8:48 pm
Q
 Q
(@q)
Wow @jsw - that is involving - clearly beyond my reach 😉
@cwbullet - I don't see copper indeed.
Veröffentlicht : 30/07/2021 1:46 am
